kpinnc 11,877 #1 Posted October 5, 2008 Trying to figure out how this works. This rectifier was originally on the twin Briggs I've re-powered the 520-H with. It is an Onan rectifier, nearly identical to the one on the P220. For whatever reason, I'm getting no DC volts from this or the other rectifier from the P220. Both rectifiers are labeled exactly the same, with 2 tabs marked "AC" and one labeled "B+". There are two wires coming off the stator on the Briggs, and I'm reading 20 volts AC from the stator, and that's exactly what I should be getting. Trouble is, I see only about 2 volts DC on the "B+" tab on both rectifiers. My understanding was that I should get about 14 volts DC... What am I missing here? I'm connecting both AC wires from the stator to the tabs labeled AC, and I've tried both rectifiers with them grounded properly. Here's a pic of one of them: Here's how they're labeled, and the two tabs on the far right are joined together: Can anyone tell me if I'm hooking this up wrong or what? The 514 isn't as much fun when I have to recharge the battery after each use. Thanks! Kevin Share this post Link to post Share on other sites
Curmudgeon 28 #2 Posted October 5, 2008 The wiring diagram in the Electrical Demystification Guide (page 7-107) does not have the two posts joined. That didn't sound right to me anyway. How can the AC and DC circuits share a post? The diagram shows the wires coming from the stator to the two AC posts, and a lone wire running from B+ through a fuse to the battery. Share this post Link to post Share on other sites
kpinnc 11,877 #3 Posted October 5, 2008 How can the AC and DC circuits share a post? Dunno Dale, I've been scratching my head on that one too. both of the rectifiers I have (Both Onans) are the same way. B+ is connected to an A/C... Go figure... Kevin Share this post Link to post Share on other sites
WheelHorse_of_course 99 #4 Posted October 6, 2008 If B+ is not connected to the battery it may not work properly. On the older Kohlers this will cause the regulator to heat up and eventually fail. Onan may have put in protection against this that is causing the problem. I agree that the B+ should not be jumpered - I would remove the jumper and connect the B+ to the battery and see what happens. best of luck :banghead: Share this post Link to post Share on other sites
