By
WHnoob
I finally got a couple hours of shop time to try to assemble one working tractor from the C-160 (broken tranny) and B-80 (broken engine), both 1974's. The short-term goal is to move the 4-speed from the B-80 into the C-160 in time to use it for snow-blowing this winter. Then over the winter I can work on rebuilding both the 8-speed from the C-160 and the K181 on the B-80. So I got both transmissions detached from their respective tractors and it looks like everything should bolt right up - even the input pulleys are the same size!. However I encountered two problems with the 4-speed so far:
1. The right hub is turning on the axle, so something is obviously wrong with the key/keyway. I don't currently have a hub puller to see what's up.
2. The left wheel is stuck/rusted to its hub. I tried some PB blaster and pounding a cold chisel into the gaps between the wheel and hub but it didn't budge. I wanted to just switch the wheels, since the C-160 has larger diameter tires (though the wheels are the same size), and the B-80's tires aren't looking so great. But maybe the C-160 will just have to have a low rear end for the winter.
