Kennedy
Solenoid bracket
Kennedy
My dad has a c-81 with the Kohler k181s. The bracket on the top of the solenoid cracked and no longer grounds the solenoid and is preventing it from starting. Is there a way to remove the bracket from the top of the solenoid to replace it or make a new one? Are these still available?
Thanks
Mark
rmaynard
That solenoid is still available. I purchased one from TSC about 2 months ago for $10.00. For the small amount that it cost to buy one, it's hardly worth trying to fix.
http://www.tractorsupply.com/en/store/buyers-motor-solenoid-12v?cm_vc=-10005
gregg'shorses
Just a  internally grounded solenoid available at Napa.
Kennedy
Thanks guys.
oldredrider
You can also weld the bracket back together and it will work fine. Done it many times.
Marv
I welded one of mine.
Marvin
