stevebo
Stevebo's Barn Build
AMC RULES
Calling for lots of wind over this weekend Steve.
stevebo
If that is the case then I will not be installing the roofing panels but will be trying to finish the siding....
stevasaurus
Steve, the barn looks fantastic.  :)
stevebo
Today I finished off the deck and did some more detail work. The guys doing the framing are done for now. They will need to head back next week or the week after to hang doors, build the bench and a few other items. Cutting wood inside the barn is officially done (for now). I am sick and tired of saw dust and picking up scrap wood. I used the blower to clean up inside and get things somewhat cleaned up. I just could not get myself to work in those conditions. My goal is to get all the siding done 100% and install all the windows by the end of the weekend. I believe Fireman is willing to come over on Saturday morning. I could use help from anyone else who is willing to come over and help. Pretty easy work just takes time. Let me know if you are willing to help hang some shiplap siding on Saturday. Thanks !!
Ken B
I have prior commitment's this coming weekend...
Nathanielperz
You wanna sell that four wheeler Steve?
-Nate
stevebo
Nate- I just bought it this week. I need to replace the sprocket and chain. Runs really nice. 1991 Honda Four Trax 200. It will be on hauling firewood out of the woods at my friend's place.
Here are some pics of the standing seam roofing. I plan on installing the front half myself. I will continue with panels tomorrow afternoon and Saturday morning until early afternoon.
Ken B
i hope that 4 wheeler being in the barn is just temporary.. It kinda kills the ambiance... :ychain:
stevebo
Ken-
Your job is to help install the stove pipe.... It needs to be done right!!
km3h
That roof will outlast your grandchildren. First class al the way.
stevebo
Nick-
My company manufactures this standing seam roofing panels. I ran the wind uplift calculations to determine the correct clip spacing for proper install. The way this system works is it is only attached at the ridge (fastened to the clip) and the rest is allowed to move up and down for thermal movement. This will eliminate the "oil canning" which is the waves in most standing seam metal roof systems. We tested this panel for static pressure ASTM testing method and it is the best panel on the market. I had all the panels cut to length at our factory so no need for cutting. I hope to have this installed by the end of the weekend.
JERSEYHAWG /  Glenn
Just caught wind of this thread. What a great space. You will luv it for sure.
Glenn
JERSEYHAWG /  Glenn
Nick-
what numbers up where you live for the 8 second gust? Just curious. The calcs are always overkill,,, but,, as we see they work.last hurricane taught us that. Most of the time anyway........my dream building. Looks really super duper.
Wheel horse cozy.
Glenn
km3h
House I lived in when I was very young had a tin roof. I rally like to lay in bed and listen to the rain beating against it. it was loud, but I found it soothing and usually fell asleep with no trouble. When you get a nice cherry red color on that stove and it is raining outside you will really know that you have built your MANCAVE.
stevebo
Glenn,
Per code we ran the calculations at 95 mph and basically open terrain. I can check the specifics but we needed to have the clips spaced every 5 feet apart in the middle of the roof and every 4.5 on the perimeter. I ended up going two clips up top spaced 2 feet apart and then every 4.
JERSEYHAWG /  Glenn
Thank you. Figured as much. More is better. Imho. Lol..Oh yes. I am well versed with "the code" thanks Steve looks great.
Glenn
stevebo
This afternoon Jeff (Fireman) stopped over and helped me install more panels on the front. Here is where we stopped...
  • Like 4
KyBlue
Looks great!
Nathanielperz
I've been looking for a four wheeler like that for a long time hahaha Its gonna be a great machine for getting firewood... im surprised you don't use a horse for that though.
-Nate
That barn is going to be awesome! Can you come build my father one next? Hes always want a woodworking shop! :ychain:
-Nate
stevebo
Had some more help today and was able to get the upper deck railing built and the remainder of the back siding done. Thanks again Fireman and Cousin Timbo !!
  • Like 7
AMC RULES
Looking really good you guys...   :handgestures-thumbsup:
am I seeing tractors accumulating in there already?
stevebo
Yes Craig. I wanted to get the ones that were outside inside...
squonk
You going to put any kind of waterproofing stain on it Steve?
stevebo
Mike-
I am planning on staining it with an oil based brown stain. I think it will be a little darker than the "survivor" barn but not as dark as the roof. Not sure that will happen before winter or not. It may have to be a spring project...
AMC RULES
Time for one of these...
  • Like 4
  • Similar Content
    • Travas
      By Travas
      Hello everone reading this. Im currently in the process of building a race mower out of a front engine 8-32 toro. It was sitting outside for the longest time because of a broken axle. It believe it has a vertiical 8 hp b&s that had running. Here is some some photos of it.  I put a bifferent transaxle in because it was spare one laying around. I put it on and it fits pretty well. Altho i had to remove all the clutch and shifter parts to get it in, but hey it works. I got a wheel on and tried getting the other off the axle it was on. So i put it in the press and tried for about a half hour before in popped loose. After that it took me about 15 mins and got it off. It was really  rusted on there! Put it on the transaxle to how it fits and looks. Now im in the process of drilling a hole the axle for the key in the wheels. Any suggestions or ideas? I will update this project when do some more work on it.
    • mmmmmdonuts
      By mmmmmdonuts
      I have approximately an 10x12 lean to shed attached to my house on the side of my side loading garage. I currently have a double door that is 6' wide by 6x10" high. The problem I am having is the door starting to fall apart. It is also framed very heavily with 2x6s. So I am currently looking to either do another double door or a garage door. Part of the reason the door is getting damaged in the first place is because water pools at the bottom of the door in the winter and freezes and I have to basically heat and or chisel the ice away. It is where I store my snowblower.
      My wife ruled out a sliding barn door and a roll up door mainly for appearance purposes.
      I was starting to lean to a 8w x7h regular garage door but see a few cons.
      1) It would block the light when up.
      2) I would lose quite of bit overhead storage and about 2 feet of wall space.
      3) There would be much more work reframing parts of the wall to fit the door.
      Pros.
      1) I could fit my wheel horse plow and snowblower side by side.
      2) Shouldn't freeze to the concrete as easily with a rubber seal.
      3) Don't have to shovel out the doors to get the snowblower out.
      I was wondering what thoughts you guys had on and if I am missing something.
      Thanks.
    • CasualObserver
      By CasualObserver
      I've been dreaming of a new shop space to work on tractors and generally store things at my house. We already had a three car garage on the house and could only fit one vehicle in it due to the large space that kids toys, bikes, zero turn mower, shelving and a workbench already occupied. Well.. that stuff and a few or so little garden tractors... but they don't take up that much space, right?   Anyway...  we'd been talking about building my dream shop for several years. We live on a large in-town parcel, so there's plenty of room, but as with most things, it comes down to when it can fit in the budget. I drew it up several times on the building designer at Menards dreaming of when we could go forward. Well, in the early 2017 we decided to go ahead with it, and I came up with my final layout plan.
      We proceeded under the option of build the shell, and finish what we can later. We went over and over the list of things to do now and later. Things I wanted that had to be done now for sure were the rough in for the in-floor heat and the attic trusses. I had a contractor friend who would GC and frame it for me if I bought all the materials and he could do it on his own schedule. Yep, done. I figure I could have built it myself, but it would have taken most of the summer of every night and weekend, as well as the headaches of arranging the subs for the stuff I couldn't do, but if he could do it, and he has all the contacts/subs already... I'm money and time ahead to work some extra overtime and avoid the headaches.
      The previous owners of our place had a gravel RV parking next to the house. The old poorly done timber walls were deteriorating and leaning with age.It was convenient for parking the trailer, and nice when the kids were little that we could park off the driveway so they could play, but every year inevitably it was always a weedy mess by mid-summer.
      Step one, remove ugly timber wall.  Lucky for me my neighbor had an chainsaw with a garbage blade on it. He came over and we were able to cut the wall into 12 ft sections that we loaded on the trailer for the dump.
      Next, met with our contractor friend to stake and mark it out. Since part of the goal was to reduce the amount of gravel, the equivalence of one car parking space was being removed and returned to grass on the left edge.
      Then just before the excavator was to start work, the kids and I did a little groundbreaking for the big project.
      Some gravel removed and sand base laid down and compacted.
      Concrete guys laid the forms for me on a Friday night so I could lay the insulation and pex for the in-floor heat.
       Like any kids, the call of the sand pile was irresistible.
      Next day I had help to lay the insulation boards and pex. Might seem silly to see two people carrying these boards that weigh all of 2 lbs each... but notice all the pavers? I'd been hoping for good weather to do the insulation and pex..... what I got was great temperature, bright, sunny......and 25 mph sustained winds with 40-50 mph gusts. So.... two guys to carry each flippin' board and weight it down. Ugh.... made the process much longer.
      Got the pex down, which went very smoothly. Three zones, stapled to the foam board.
      Monday morning I get a call.... inspector won't pass it because there's no pressure test on the pex. Ugh. Nothing about that in our building code, but what am I going to do? Project can't go on without his initials. So... I build a pressure manifold, tie all three zones into one long line and charge it up.  Tues morning, concrete guys are onsite... inspector shows up and says ok.
      By the time I get home from work, I have a new slab.
      Lumber pack shows up the day before the family and I are leaving for a week at the cabin. When I pulled out of driveway, construction was underway. We got a few progress pics through the weeks from various friends.
      And I returned a week later to this.  Totally the best way to build a shop!  I was out of his way, he was out of mine... worked out perfectly.
      I installed the overhead doors, had the electrician come and trench the electric over. Got the gas line roughed in for the boiler as well while the trench was open.
      After that, the excavator came back with the final top dress for final grading.
      We bit the bullet and decided to go with sod right away. Even got the kids to help for a little while. Couple of neighbors (one of whom happens to be a professional landscaper) came over the chip in too, and three pallets later....
      Now we're at slow progress time. I bought all the construction materials on a Menards 11% rebate, so once I got the rebate check I started to finish the interior. Got the vapor barrier up, and ceiling rocked with 12 foot 5/8" type x. 105 lbs each. Ugh. Thank God for drywall lifts, right!?
      More rebate checks allowed for the insulation and rock for the walls.
      Then we came to a complete standstill..... got enough stuff moved out of the house garage to get both the car and truck in for the winter, but with no heat and no ceiling insulation the shop was just a big storage box for winter.
      Spring this year rolled around and prioritizing shop work made it to the list. I realized it's going to be much easier to get the interior done before I move in. So... started back at it. I got the floors masked off and got tape and mud done... then the girls helped me paint.
      Did the floor with Rock Solid polycuramine kits from Menards... grey with flakes and a textured topcoat to make it less slippery if wet. This is a long and multi-stage process. First it required renting a diamond grinder and grinding off the curing sealer. Then powerwashing three times to remove all dust and debris.  The base coat went on, cured for a few days, and topcoated three days later. Then I let that cure for a week before moving in. It's supposed to be cured in 24 hours, but why rush it if not necessary?
      Finally ready to move in.
      Got some used kitchen cabinet take outs and installed them for the workshop area.
      Really looking forward to getting stuff organized and cleaned up now.  It's totally a dream come true. Still have to buy and install the boiler and get the ceiling insulated... but those are things that can be worked around. Up until this point it's been much easier to have minimal stuff in the way.
      If you made it all the way to the bottom, thanks for taking the time to read it.  Get more done, have more fun!!
    • Pullstart
      By Pullstart
      Pretty soon, the tractors will have a place for everything and everything in it’s place!
      We put up another section of racking and it will allow for some custom pallets at 66” long and 44” wide to store tractors 3-wide in the racking.  The closest green upright is 9’ tall, it’ll be a shell for the buggy to rest on top of
