Mgbchuck
Dash lights on my 312-8
Mgbchuck
Howdy.....I have a 312-8 tractor. On my dash..... I have a series of 5 lights that I believe test your system. When I flip the test switch.....the only light that flashes is the oil light. Not sure what this means...... I was assuming.....I was low on oil....... But I always check my oil level....and it is at the full mark. I have even checked it with the engine cold.....and ten minutes after I have mowed. Still looks good. My old owners manual didn't exactly tell me what the lights mean. Any help out there......
Thanks..... Chuck Lyons. Akron Ohio
gwest_ca
The test switch verifies the lights work. The oil light is the only one that flashes when activated. The others should come on steady but sounds like they no longer work and this has no effect on the operation of the tractor. If working correctly and the tractor will not start or run the appropriate light will indicate which circuit is affecting operation.
Here is a good bulletin on the low oil switch. Very important.
Garry
Geno
Garry is right.  I have a 414-8 that does the same thing.  I never looked into the other lights not working.   :)
Save Old Iron
Chuck,
check out this post.
Chuck
Warning:Unsupervised
Hi'
 What happened to the oil light bulletin Gary posted & link to other posts mentioned here by SOI? I don't see them, am I just missing something here or have they really disappeared? Thanks
WHX??
Older thread but maybe still in the basement? Mods can you help 123 out?
BTW-
 Does running straight vs Multi weight oil change how the pressure switch/lights act? Working on a friends tractor and he runs Multi, I always run straight 30 as per manual myself. Thanks
nylyon
57 minutes ago, 123GO said:
Hi'
Fixed
WHX??
Thank you Coach
Knowing how they work I wouldn't think so.
Recent thread here if it helps 123...
Edited by WHX24
Wow you guys are on the ball man!!
I didn't know how it's designed when I was asked about it.  I agree, after viewing this it really can't effect it.
 We were discussing changing oils in our tractors today and the subject came up? Good to know how these operate, all you folks here are so much appreciated. Big Thanks!
  • Similar Content
    • ebinmaine
      By ebinmaine
      I know this subject has been covered multiple times over the years. We have a lot of new members and many of us like to refresh ourselves too.
      Please feel free to post links to old posts as well.
      So what can you share with everyone about plowin' the White stuff??
      Common things like what tires and weights.
      Why you prefer a certain tractor. (Please Be kind to others as we have different needs and opinions).
      What orange/amber lights are required by your local officials while in the road?
      How much space do you save for future snow piles?
      Is there anything you found that was unplanned for that the rest of us should know?
      Whatever you can / care to share.....
    • Jack Oldham
      By Jack Oldham
      Hi All,
         I have a question regarding doing an electric mod on my Wheelhorse A800 Ranger. What I wish to do is install some front headlights, rear brake lights, and indicators on all four corners i would also like to install a horn a some point but that can come later. I'm unsure on the best way of wiring this, what gauge wire to use, do I need a fuse if so what ampage and where also what size amp hour battery is best to use if I'm running these additions so i don't drain the battery. I understand more how I'm going to wire the indicators than how I'm going to get the break light to work but really require advice on both.
      Thanks for you time in reading this.
      Jack Oldham
    • Petes Horse
      By Petes Horse
      I've been looking for a while. The bolt holes just line up and the wire is a little tight between the fender and light. No drilling though.
      They were at Rural King. I think about three bucks each. Optronics MC42RS RED  Marker/Clearance.
    • edwroy
      By edwroy
      So my question is: when adding cab lights do you wire directly into the light system of the tractor or do you wire to the battery with a fuse wired in line?
      Would be interested how some have wired their lights.
      Thank you,
      Edwroy
    • edwroy
      By edwroy
      Hi,
      Would be interested in what people are using for cab lights when plowing or blowing snow.
      Thank you
      Edwroy
