asmith4901
Hello. I just aquired a b100 (circa 1975) and want to repaint. My question is this. Is the red of the kohler engine the same red as the rest of the machine? The other paint codes I can find easily on the forum. Thanks for any advice.
rmaynard
:WRS:   Kohler painted their engines at the factor with a color that was close to, but not exactly like Wheel Horse red. If you notice, the color on the engines tend to stay red longer than the sheet metal on the tractor. Kohler also used gray primer under the paint on the sheet metal. Wheel Horse did not use primer at all.
Most restorers just paint the engine with the same paint as the tractor, at least I do.
