KC9KAS
Re-Wiring my C-160
KC9KAS
After checking out my C-160 and rebuilding the carb, I am now working on the wiring.
I did a search on re-wiring and found a lot of really good information on members re-doing their tractors.
So here are some photos and comments....
Special crimpers for the female treminals that fit inot the Packard 56 connectors.
Purchased items for the re-wire job
Bought "Packard 56" connectors in packages of 5. Bought 5, 4, 2 and 1 position connectors. I am always needing good quality connectors for something.
Various colors of wire.
This is what needed replaced.
Hard to see, but all wiring and connectors are complete and now I need to fasten the wire harness to the frame.
  • Like 5
squonk
All those wires hanging remind me of some of the tractors I've gotten that looked that way and the owners were using them!  :scared-eek:
KC9KAS
This thing was so "Jeri-rigged" wiring wise.
No on/off switch, push button start button, missing coil...........needless to say, it wouldn't start!!
Wheel-N-It
I enjoy seeing a good quality wiring job on Wheel Horses or any other LAGT ! Don't forget to use wire looms and tie wraps where you can. Are you wiring in all the old safety switches, or leaving some of them out (old school style) ?
dclarke
Good info to have, I'm gonna need to do this to mine some day. Thanks!  Looks like you're doin a good job! :thumbs:
JERSEYHAWG /  Glenn
Nice clean job your doing.
Glenn
Martin
Ken,
I see you are making progress. i think that old harness got thrown out. looks like you have it under control. these ones are a fairly basic harness to do on the tractor and work out the lengths as you go.
nice to see all new components!
looking forward to some finished pics!!!
  • Similar Content
    • CHuls
      By CHuls
      *Estate Sale*
      71-16KS02 1977 C Series Garden Tractor C-160 Automatic Kohler K341S-71223A 16hp Sundstrand Hydrostatic 90-1140
      Comes with mower deck (not sure but, I'm told it's a 48") & 42" plow blade model/sn 42BC01 08580 7276
      Been sitting for years, haven't been able to get it started. When I put a little gas in to try starting it this year, it leaked from the tank, probably cracked fuel hose
      Not sure what it's all worth together but, make an offer.
    • PMeadows
      By PMeadows
      Thinking about selling my 1974 C-160 and hoping to get a feel for interest. It has working hydraulics, front plow, single row rear plow, 42" belly mower deck, 55lb wheel weights. Runs fantastic, no smoke. Lights work, amp meter works, has plug in cigarette lighter (doesn't work). Left rear wheel cylinder has slow leak.
    • Hoppy Rabbit
      By Hoppy Rabbit
      I went to a wheel horse show in PA and picked up a B-100 Automatic. I restored and cleaned it up after I brought it home. It had everything except the Headlights. I got a lense and looked online for the housing and cable. I found one on ebay except it was $67 plus shipping. It didn't even have all the parts. https://www.ebay.com/itm/265133794229?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=dhBhG47STyW&sssrc=2349624&ssuid=&widget_ver=artemis&media=COPY.I was just wondering if there is anywhere to get a cheaper one with all the parts so I can finish it.
    • RJ Hamner
      By RJ Hamner
      The C-160 just wasn't running right. Started with new points, plug, filters.
      I had put an aftermarket carb on it but had found a good Carter N in the correct size so I rebuilt it.
      Got it started this afternoon and had it running at about half speed to warm it up so I could make the final adjustment to the carb.
      It purred along for about 4 minutes and just quit.
      First thought was "out of gas".  Looked in the tank and sure enough it was really low so I filled it up.
      Tried to start it again .....NOTHING
      Went and rechecked everything ....NOPE
      Got out the can of starting fluid...NOPE
      Pulled the plug and noticed the gap was ZERO.  Re-gapped and tried again.  Same thing again no gap.
      Pulled the head.  Looked normal.
      When I cycled the engine I noticed that the exhaust valve didn't fully retract.
      Was able to remove the exhaust valve with two fingers!!!!!
      Guess I am in the market for a new set of keepers and a few gaskets.
      The guys at McHenry's Small Engine Love Me
    • tractorman99
      By tractorman99
      Hi everyone,
      I bought a wheel-horse c-160 a while back, and did some work with it.
      One day the rear axle housing broke:
      I was thinking about changing the part or soldering the broken pieces.
      Does anyone know where to order this part? Or has any idea of the potential cost of a soldering job?
      Thank you in advance!
