jb4249 131 #1 Posted July 19, 2014 Question about the steering on my RJ 58. It was very stiff when I picked it up, so I have disassembled it and cleaning and greasing all parts. Me question is the pin in the right end of the tie rod is welded in place. Is that factory? I can't tell from the diagrams. Also the welding on the spindles look 'home made'. I'll get some pictures of this if it helps. Just wondering if these 2 things sound original. Thanks, jb4249 Share this post Link to post Share on other sites
Racinbob 11,291 #2 Posted July 19, 2014 They did not come from the factory welded but it's common to see them welded up after they wear. Share this post Link to post Share on other sites
Jake Kuhn 1,556 #3 Posted July 19, 2014 If you are referring to the right side of the tie rod, as if you were sitting on the tractor, and it is the side that connects with a snap ring yes that would have been welded. But the pins like what are on the other side, and go in the steering block are not welded. Share this post Link to post Share on other sites
formariz 11,988 #5 Posted July 20, 2014 Question about the steering on my RJ 58. It was very stiff when I picked it up, so I have disassembled it and cleaning and greasing all parts. Me question is the pin in the right end of the tie rod is welded in place. Is that factory? I can't tell from the diagrams. Also the welding on the spindles look 'home made'. I'll get some pictures of this if it helps. Just wondering if these 2 things sound original. Thanks, jb4249 I always wondered about that since I have one where they are all welded. Can you post a picture of yours? Thanks Share this post Link to post Share on other sites
jb4249 131 #6 Posted July 21, 2014 I'll get a couple of pictures tomorrow and post them tomorrow evening. Share this post Link to post Share on other sites
jb4249 131 #7 Posted July 21, 2014 Here are the pictures. The right end of the steering tie rod and I tried to get both of the spindles. The right one looks like a factory weld but the left ones looks home made. Ted Share this post Link to post Share on other sites
ricksrj58 273 #8 Posted July 21, 2014 the bottom one appears to have been repaired Share this post Link to post Share on other sites
