Sparky-(Admin) 22,099 #1 Posted September 30, 2008 Hey guys. The starter soliniod was sticking ON after the key was turned off on my 1989 312-8. I almost bought anew one today but I was pressed for time and couldnt stop off at the dealer for one. Got home and removed it to find that its not a sealed unit like I thought. Its held on by 4 tabs. By bending 2 tabs you can work it out easily. Once its out you can see right into it from the backside and it wasnt moving smoothly so with nothing to loose I sprayed some silicone lubricant (small amount) into the center where the "plunger" is and worked it in by pushing gently on the end of the plunger with a small screwdriver a few times. Put it all back together and it works fine. I tried it like 15 times and it released everytime . I included a pic of the style solinoid I have. Mike....... Share this post Link to post Share on other sites
Duff 206 #2 Posted September 30, 2008 Hi, Mike! My '89 312-8 has just the opposite problem- sometimes (but not always) when I turn the key the solenoid snaps but the starter won't kick in. Second or third time it engages properly. I wonder if mine is sticking likes yours, just in the "out" position? I'm going to try your trick and see if it makes a difference! Duff :banghead: Share this post Link to post Share on other sites
Sparky-(Admin) 22,099 #3 Posted October 1, 2008 Good luck. I dont see why it wouldnt work for your problem either. Mike......... Share this post Link to post Share on other sites
