I finally got a chance to rebuild a transmission with a hi/low mechanism. This is a 6 speed #5060 transmission with the 10 pinion limited slip differential. Notice the brake shaft comes out the hole closest to the axle housing. The 8 speeds brake shaft comes out of the cluster shaft hole. I did a series of videos for this thread along with some pictures. The videos are split up between different phases of rebuilding...ie...the differential, the hi/low shift mechanism, the rest of the gears
