rnsdoughty 0 #1 Posted July 15, 2014 I have a 1969 Raider 12 with an 8 speed transmission. Both rear axles have a hair-line crack about 1.5" from the outside end. Has anyone else run across this and if so what did you do about it? I do not know what model transmission I have.. I had thought about purchasing new axles but do not know where to go to find them (I also do not know a part number for the axles). My next thought was to take the axles to a machine shop and see if they can fix them. Does anyone have any thoughts on how I should solve my problem? Thanks for any help given. Rod Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,461 #2 Posted July 15, 2014 This should be the original transmission Garry 1 Share this post Link to post Share on other sites
racinfool40 203 #3 Posted July 15, 2014 I have good used axle's if needed...I wish ya luck finding new ones..They are almost impossible to find for the 10-pinion differential which you should have in your trans....PM me if interested. 1 Share this post Link to post Share on other sites
rnsdoughty 0 #4 Posted July 16, 2014 I have good used axle's if needed...I wish ya luck finding new ones..They are almost impossible to find for the 10-pinion differential which you should have in your trans....PM me if interested. I am new to the Red Square Wheel Horse Forum so do not know If I am doing this correctly. This is meant for racinfool40. I am interested in the axles that will fit my Raider 12 Wheel Horse. I heard from another member and was told that I have a Wheel Horse 5071 transmission and that the part numbers for the rear axles are 7202 & 7203. Please let me now what the price for the two axles are and how to go about completing the purchase Thanks for the help. Rod rnsdoughty@comcast.net Troutville, Va. Share this post Link to post Share on other sites
