ssecoy 0 #1 Posted July 14, 2014 I recently picked up an older wheelhorse with a 16hp onan but can not locate the serial or model#??? I'm assuming the sticker is gone. Can anyone help me figure out the year and model? Share this post Link to post Share on other sites
WH nut 553 #2 Posted July 14, 2014 (edited) With the information given all I can say is its Red. With no other info a picture would help. And to ass, not being an azz, just need some basic info. And welcome to RS Edited July 14, 2014 by WH nut Share this post Link to post Share on other sites
oldredrider 2,548 #3 Posted July 14, 2014 A picture (or 2) is worth a thousand words. 2 Share this post Link to post Share on other sites
Desko 608 #4 Posted July 14, 2014 It could be a D160,416,or a 516 Share this post Link to post Share on other sites
ssecoy 0 #5 Posted July 14, 2014 I will have to wait untill I get off tonight to upload pics but I just throw it out there and see what yall said. It is hydrostatic and has a levet for "lift". I'm sorta new to wheelhorse so that's all I know for now but will update with pics in a few. Thanks for the replies Share this post Link to post Share on other sites
C-101plowerpower 1,605 #6 Posted July 14, 2014 off white or grey/silver rims? Koen Share this post Link to post Share on other sites
ssecoy 0 #7 Posted July 14, 2014 Silver Grey/silver with wheelhorse hubcaps Share this post Link to post Share on other sites
C-101plowerpower 1,605 #8 Posted July 14, 2014 if they are grey/silver i'm thinking it's a 416 or 516 Koen Share this post Link to post Share on other sites
ssecoy 0 #9 Posted July 14, 2014 I've seen a 416-H online and looked like an exact match but I'm just not sure Ill upload pics of everything later.. I plan on restoring it, It needs a coil and a new mower deck then it would be complete. Is this one worth restoring? Share this post Link to post Share on other sites
C-101plowerpower 1,605 #10 Posted July 14, 2014 depends on how the overall state of the machine is, coil could be expensive being a 2 cilinder onan, but then again i don't own one so it's kinda hard to say Koen Share this post Link to post Share on other sites
ssecoy 0 #11 Posted July 14, 2014 A friend told me that a dual fire harley coil would work as long as it is between 2.9 ohm and 3.6ohm. It looks the same but would anyone know if this is true. If so this coil is only $36 on Amazon but again I'm not sure if it will work Share this post Link to post Share on other sites
Brrly1 1,146 #12 Posted July 14, 2014 I think that only pertains to the Kohlers, I may be wrong. Share this post Link to post Share on other sites
boovuc 1,090 #13 Posted July 14, 2014 I know it pertains to the old Kohler KT engines. I don't know if it would work for the Onans. Share this post Link to post Share on other sites
ericj 1,578 #14 Posted July 14, 2014 down load the onan service manual on here and it will walk you through step by step how to trouble shoot your onan and make sure you only replace what you need to or want to because parts are not cheap. try onan parts.com for parts good luck and keep us updated eric j Share this post Link to post Share on other sites
ssecoy 0 #15 Posted July 15, 2014 Its a 416-H! I overlooked the writing on the sticker on the hood.. now as far as year I'm guessing 1990 only because I seen one on CL that looked the same. How does the rear end work on this? My first hydrostatic Share this post Link to post Share on other sites
Desko 608 #16 Posted July 15, 2014 Its an Eaton 11 pump they work by pressurized oil. Great score needs some TLC but will turn out great! Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,029 #17 Posted July 15, 2014 It may be a 1996 416-H model 73423 Serial 6900001-6999999 Garry Share this post Link to post Share on other sites
ericj 1,578 #18 Posted July 16, 2014 it's a 1990 416-H the 1990 416 kept the same MCL controls as the 88, 89 hydros were as the 520's were moved to the steering column in 91 the 416's were also moved to the column good luck eric j Share this post Link to post Share on other sites
