Swemill
Work with the D-180 (pics)
Swemill
Thought I should share some pics of work with the D-180.
My father needed a new layer with gravel stones on his yard and took the Horse to the local quarry.
This is located about 7,5km away and gives a trip about 15km / 9 miles each turn. He drove 5 turns with no problem…. =)
The first turn he took a little too much load and nearly got stuck in the hill with spinning tires… He had about 1350kg / 3000 pounds on the wagon. The other turns he got about 500 pounds less.
With the biggest load this carriage weight was about 2800kg / 6200 pounds. Fairly heavy and it went very fast downhill’s…. The hydro couldn’t slow the speed down (from full hydro) because of the weight and mechanic brakes would be nice to have… With not full speed on the hydro before the downhill it worked better and it could hold the force.
  • Like 3
Pollack Pete
Hi.Nice D-180.Good to see a big horse getting a good work-out.How many miles per gallon did you get.Ha,ha.
Brrly1
Good to see everyone out having a great day. Tractor and trailer look real good, nice setup.
JERSEYHAWG /  Glenn
A beast of a worker. Thanks for sharing that with those good pics.
Glenn
Glenn
  • Similar Content
    • BuffaloD200
      By BuffaloD200
      Hey all, I need to install a drive belt on my 75 D180 for my snowblower.  I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure.  The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell.  Do I have to remove the PTO pulley?  That seems to be a required service item.
      Same question for my 80 D200 as well really.
      Using the recommended 4L490W belt.
      Thanks
    • Redtickuleez
      By Redtickuleez
      Hello gentlemen!!! I recently bought a d180 with loader and backhoe. Im looking for serial number.. there is a plate under the steering wheel but its been pajnted over and i can make it out. Can y'all tell me another location and was this tractor pruchased originally with these attachments and any info would be greatly appreciated... Thanks fellow Wheel Horse enthusiasts !!! !! !!!
    • ihatephones
      By ihatephones
      I got a D-180 for $250, and the governor is messed up, the points won't open or close, and I took it apart and was being stupid and messed some stuff up in there, and now I need a new one.
      Where can I get one that's not on eBay for $200?
      I also forgot to say it was a Kohler K482, and I'll throw some pictures of the tractor in as a treat.
    • Southern_Secret
      By Southern_Secret
      Hello fellow Horse Heads long time no post for me, life gets crazy & a lot of things change sometimes but anyhoo. So back a few years ago when I first got my 1994 314-H I had it at my shop going threw it. One of my customers walk past as im working and said, you know I think Iv got a Wheel Horse & im thinking "no you dont buddy". I give him my # to send pics thinking it was a big waste of time & after getting the pics I realized he did have a Wheel Horse! I hand shake bought it right there, asked him to bring it to my store & he said no problem. Well after almost 2 years it is finally in my orbit. I know very little about it other than his father-inlaw got it new and used it around his house moving snow and stuff. His father inlaw moved down south here when his daughter got married and gave the tractor to my customer because he had a farm & his the inlaw had no use for it anymore. Same with every barn find, "it was running when parked" 8 years ago, said one of the axel seal is leaking. Im happy and hope I can get it back in running order soon cause it is going to be handy around the truck farm!!
      I will post Pics as soon as I reinstate my membership
