j main 5 #1 Posted July 9, 2014 Hello Guys Dnt know if im in the right place.But here gos I have a Raider 10 and my question is can someone plz tell me or diagram on how to adjust the brakes? I can push the pedal really all the way to the front Before it will stop.Even when you go to shift gears .You have to push that pedal really far.Or does The pedal need adjustment? Thank you for the help Jeff Share this post Link to post Share on other sites
stevasaurus 22,987 #2 Posted July 9, 2014 Do you know what year your Raider 10 is?? It could make a difference. Did you look at how thick the banding material is under the brake band?? If that is kind of gone, replacing that could just solve your problem. We have a few places to acquire the material if you think that is what is going on...new material is about 3/16" to 1/4"...probably 3/16". Check and see what you have there. Share this post Link to post Share on other sites
j main 5 #3 Posted July 10, 2014 Hi Steve I really dnt know what im looking at.Do you happen to have a pic to look at? as far as year goes I think it is a 72-75 model .is it an easy fix?And where can I get the parts from Thank you for all your help Jeff Share this post Link to post Share on other sites
chazm 413 #4 Posted July 10, 2014 Here pic of brake band & adj on a314 ,but basically the same set up , hope this helps Share this post Link to post Share on other sites
Zeek 2,286 #5 Posted July 10, 2014 (edited) I have a Raider 12. Mine is adjusted by tightening the nut in the picture at the end of the rod where it meets the band like Chazm said. Edited July 10, 2014 by Zeek 1 Share this post Link to post Share on other sites
j main 5 #6 Posted July 10, 2014 Hi Guys I want to thank you.Zeek and Chazam I now know what to look at lol.Im dumb when it comes to these Tractors my only other question is do you have to take off the wheel to get to it? Thanks Guys and Steve Jeff Share this post Link to post Share on other sites
stevasaurus 22,987 #7 Posted July 10, 2014 It is one heck of a lot easier if you pull the wheel...your work is in front of you then. Check the thickness of the material inside the brake band...3/16" is what new is. I think "Dave's tractor world" is selling the material if you think you need it. The band pulls off by removing the 2 7/16" bolts on the top left. Share this post Link to post Share on other sites
Zeek 2,286 #8 Posted July 10, 2014 My wheels are spaced a little wide so I can get a wrench on mine with the wheel on. Share this post Link to post Share on other sites
j main 5 #9 Posted July 10, 2014 Thank you guys for your help Jeff Share this post Link to post Share on other sites
