j main 5 #1 Posted July 9, 2014 Hello Guys I had a little issue with my Raider 10 .I use it all the time to mow with. I was out mowing the other day with it.When I started to go up a small incline .It acted like it didnt want to pull me.So I took it back up to the house.And i pulled the dip stick out.Guess what no oil on the dip stick.So I went to Wal-mart and bought some 80-90 gear lub I poured it in went and mowed with it no problem. What really got me was I had just bought this mower last year off a lawn mower repair man .I dnt think he ever checked the tranny fulid.Not good bussiness so I thought maybe it is leaking nope not a drop .Anyways it working fine now I could not beleave it when it was emptey he should have checked it all before I bought it .I learned my lesson Take care guys Jeff Share this post Link to post Share on other sites
rmaynard 15,408 #2 Posted July 9, 2014 Those Uni-Drives are tough little buggers. Not sure why it would bog down with no fluid unless things were getting hot, expanding, and starting to drag. In which case, I hope no damage was done. Keep and eye and ear on it. If you start hearing any unusual noises, you may have damaged bearings or other components. Good luck! 2 Share this post Link to post Share on other sites
stevasaurus 22,683 #3 Posted July 9, 2014 Yah, what Bob said...what year is the Raider 10 ??? Being a 6 speed, it is probably a 10 pinion limited slip differential...lack of oil could very well make a difference...keep an eye on her. That differential needs oil to work, the pinions float in there. Drive it easy now for a while, and let the oil do it's thing. Share this post Link to post Share on other sites
