silversolder429
1982 C-175
silversolder429
hello new guy here . bought a C-175 , really like the tractor and did a bit of research before i purchased it . my spec number is 24200 which is puts itas a series 1 , i got mixed up when i bought it thought 23400 and higher was series 2 , anyway motor runs fine but dont like what ive been reading about the series 1 oil starvation . so my question is what engines are a direct swap with the series 1 kohler and wont cost an arm and a leg ? because it seems you cant find series 2 engines , but even if i could who rebuilds them?. i just want to be ready to swap when the time comes . i need to know what others have done with thier C-175 s when they have to change thier KT17 series 1 . thank you
boovuc
Hi Ho Silver, (Sorry),
Please don't be too concerned about the Series I KT engine. Honestly, as long as you are not mowing steep side hills and/or you don't constantly have the tractor tilted for long periods of time while mowing, that motor is fine.
Here is what I have done with my C-175. Nothing! It doesn't do mowing duty anymore though. This is my blower tractor so it isn't fair to compare mine verses what you intend to do. Others have simply placed Single K Series motors in theirs if they couldn't find another KT I or II. To get close to what the 17 HP KT did, you would need a 14 to 16 HP Kohler K or Magnums. (The 16's are harder to find and are pricey).
Still others have dropped in Briggs Vanguards in their Blackhoods but they are not plentiful used though they are available new. I've even seen Honda twins in Blackhoods. (There seems to be more room under this hood design than others).
If your mowing flat or slightly graded grass, just use it. You can change up your mowing by changing directions so you don't continually have the tractor tilted to the same side all the time.
Who rebuilds them. A reputable small motor place and a good machine shop is required or you could tackle it but you'll be without it for awhile. It's the costs of the parts and they are getting scarce as well though still available.
silversolder429
boovuc , thanks for the response , i will go ahead and run it . my yard doesnt have any big or long grades on it , but again it isnt completely flat . but im sure it will do fine . just got my deck back from the shop and waiting for my new brake band , plugs ,ect..... so we can go to work :-) . im sure you can see my concern with all the bad talk on the series 1 motor ?
pfrederi
I have a series 1 with well over 2000 hours...smokes a bit on start up but runs great.  Keep her topped off on oil (maybe a 1/4" over)
silversolder429
Pfrederi , that's great!!!! little smoke no problem , glad to hear this kind of positive input . I will do as you recomend , thanks
pacer
I think once you are made aware of this peculiarity of  this model engine and can take the precautions needed it will give long service.
One thing many owners do as a safeguard (me included) is to run the oil level a bit over the shown full mark - I run mine about 1/4" over the mark.
  • Similar Content
    • Bill D
      By Bill D
      I have a GT1800 that I have swapped an M14 into.  The original drive belt is too long for the Kohler.  I tried a 7473 belt and that was too long.  I'm guessing I need an 81" belt.  Does anyone know for sure?  I'm thinking it should be the same length as a 314H?   I'm trying to avoid multiple trips to TSC with the price of gas.  Yes, I do have the correct hydro pulley on the Kohler.  Thanks.
    • 702 timmy
      By 702 timmy
      looking at upgrading my c-100 10 horse to a 16 horse. Can a k-341 fit into a c-100 space?  Any complications? Thanks  timmy
    • RedPaul
      By RedPaul
      I need some wiring help.  I am swapping a Kohler CV16S from a Scotts (JD) in to a Crapsman YT 3000 that formerly had  A Briggs engine. PO of Crapsman forgot the part about checking oil regularly. PO of Scotts changed engine oil but didn't own a grease gun thuse entire front steering gear trashed.
      Before you start throwing things at the screen, the resulting franken tractor (Scottsman CraftDeere?) is being donated for use in maintenance of a city park in the Mexican Town area of Detroit.
      The company I work for donates time, people, and a storage area for park maintenance tools and equipment. Owner is Hispanic and doe gobs of stuff for the community both personally and through our company.
      On to the question.
      I need to marry up the Kohler engine wiring with the Craftsman chassis wiring.
      The Craftsman chassis has the following wires coming to the molex connector that used to connect to the Briggs engine.
      Chassis Blue - Connected to Grey from the  Briggs
      Chassis Blue jumperd to second hole connector - Connected to Red From the Briggs
      Chassis Black and Black with white stripe - both to same connector hole - Connected to Black from the Briggs
      Chassis Orange - Connected to Orange from the briggs
      Chassis White - this wire did not connect to anything on the briggs
      Kohler engine has the following wires coming from the engine going to Molex connector
      2 Red - both go to same connection point
      Yellow
      Black
      White
      Can anyone tell me which Kohler engine wire goes to which Craftsman Chassis wire?
      Free Scotts Chassis with hydro (it would be a roller if the front axles weren't trashed) to whom ever can sort this out.
      Thanks,
      Paul
    • The_turbo_tuba
      By The_turbo_tuba
      I have a wheel horse 516-h and I am looking to swap in a kohler single cylinder model like a k-341 or k321. Or a magnum series single cylinder. Does anyone have any idea what the swap will entail, what parts will carry over and what things I should look for on the kohler. Also I believe the mounting plate on the current set up can be removed to fit a kohler perfectly like they would be set up on like a 310-8. In new to wheel horse so I appreciate anyone's help! Thanks!
    • wheelhorsejoe
      By wheelhorsejoe
      Hi Members, I am doing an engine swap in  a 1988 W/H 520H replaced Onan 20hp with a B&S 18 hp twin opposed I/C. My problem is connecting the OEM main engine harness to the B/S, the B/S has a kill wire and the alternator wire go the the regulator. My problem is I don't know what wire is what in the harness and I'm unable to find a wiring schematic does anyone know the break down of the wire harness.. Any help is appreciated..     Thanks Joe
