racinfool40
Substrand Hydro seal P/n cross reference?
racinfool40
Does anyone have a cross reference number for the 1" and 1-1/8th axle seals for the substrand hydros......
1" axle P/n 6449-????
1-1/8th p/n 5449-???
These are the numbers i came up with but need cross reference numbers...Thanks!
Martin
I think if you go to the skf cross reference engine and input the wh numbers it will give you the skf number.
let me go look......
http://www2.chicago-rawhide.com/popup_parts_lookup_457012.htm
6449       11124      ( this is the 1 1/8 seal according to the manual)
doesn't come up with anything for the 5449 though...
Edited by Martin
racinfool40
Thanks Martin..and Thanks for the correction on the P/N I had them backwards 6449 is the 1-1/8th...
