entropy
Belt tensioner hydromatic 520hc
entropy
Hi all looking for some help. I was running the mower and heard an abnormal sound, so I took off the side panel with the belt drives and found my belt tensioner to the rear drive tranny shot. There were no innards at all, I was surprised it was still holding the belt!
Anywho does anyone know where I can get a new tensioner pulley for my tractor? Or what the part number is?
To clarify, if you are sitting on the tractor it is on the right side, inline but below where the forward reverse tranny lever is.
Thanks in advance for your help.
Dave
varosd
Do you mean part # 43?    112791 part number for the 520 HC.  the regular 520 is a different part
Edited by varosd
entropy
Thanks for the schematic. I believe it is part # 44, the innards to the pulley. The pulley itself is ok, the guts are wrecked though. Any idea where I can get a replacement?
varosd
106450 part number for #44    $1.64 on partstree.com  also on Fleabay as a toro part instead of Wheel Horse
My lift lever ( #40) where that spacer goes into had wallowed out the back end of the lever and it came apart one day.  I got a used lift lever with the pulley and that spacer for $10 off Fleabay.
Where in PA are you located?
entropy
Thanks very much for the info. I am in warrington pa, about 1hr northwest of philly.
pfrederi
Just to make sure ... the pulley #43 has an internal ball bearing...
part 44 is a flanged spacer not part of the pulley and has no moving parts.  They do how ever wear out and the slot in the handle gets damaged as mention above.
entropy
Thanks Paul and Don. It must be part #43 that I need. The price is just a little more then $1.64.......... About $74 more! Pricey, but the wheelhorse is worth it and it is the 1st repair I have had to do.
I'm actually thankful this is all it was cause when it started making noise I was afraid of engine failure(as the sound came from the area near the rear cylinder). My immediate fear made me realize how much I love this machine! And also how much I would dread going back to a push mower in the interim.
So Thanks again for your help, now to get the parts and get her up and running again.
Dave
entropy
So I was going to order the part from parts tree, but decided to check my local lawn shop 1st(star lawn mower inc). The price they quoted me for part #43 was $62(a savings of $12). They would have to order but could get it. I then asked the guy if he had a pulley that was an eyeball match to mine in stock. He pulled one out that is a perfect match and costs $26.15. Awesome! And sold! Wheelhorse now fixed and saved many dollars.
I thought I should share this as the local shop was cheaper and buying there supports my local community. So cross check your local shops you may be pleasantly surprised.
Martin
Napa auto sells them also.....
Sent from my iPhone using Tapatalk
