pjgchlm
My 252-H Just stopped going into drive? Help?
pjgchlm
I have owned  a 252-H for 18 plus years and it has been great.  It just stopped going into drive, forward and reverse, for some unknown reason. It is a hydro transmission.  However, I don't know what model transmission it is??  I have noticed lately it was a little sluggish on the hills.  I'm going to assume it is a tranny issue.  How difficult is it to replace these units?  Where can I get a manual/instructions to do so?  I'm pretty handy and am willing to tackle the job.  Where is the best place to get a replacement parts?
I really want to fix this tractor.  It has been great and I know there's a lot of life left in it.  Can someone out there help steer me in the right direction?
gwest_ca
Here is a manual on the transmission
A service bulletin on the transmission oil
Make sure you don't have a sheared key on the transmission drive pulley or one of the drive axles. It just takes one of them to fail and no drive. The pulley spins on the shaft or the axle spins in the wheel.
Garry
pjgchlm
Thank you.  I will start there.  Thanks for the information, I really appreciate it.  My wheel horse is like part of my family.
pjgchlm
I just wanted to let you know that I replaced the transmission & transaxle with one I bought on ebay.  It took a little while, since I was alone, but the results are great!  My Wheel Horse is up and running like a charm!  Thanks for all your help with the manual and service bulletin.  Hoping I get another 20+ years of service from my tractor!
pencilpusher8@aol.com
Thanks for all the previous help, you guys are a life saver. I Checked all the springs on the 252H and found them to be in good shape. Since my daughter disengaged the hydro trans with the lever, I'm wondering if the little button on the pump is not returning to its proper position. How far should it stick out please, It looks like about an eight of an inch right now.
Peter G.
The button on the trans, which the lever operates, can sometimes stick.  It happened to me once.  WD40 and some light tapping/working should free it.  It doesn't move a lot, but you'll know if the tractor suddenly is in gear and isn't freewheeling.
Have you checked the drive belt?  Gear oil?  Linkage?
Good Luck!
Hi,
I found the button that bypasses the hydraulic was stuck in. after hourse f working with it, finally it popped out and now we move as intended. I also purchased a new starter for the kawqasaki enginen which I do not need,
selling it for 50.00 plus shipping if anyone is interested,
Handy Don
  On 11/3/2021 at 6:24 PM, pencilpusher8@aol.com said:
selling it
For sales, create a new item in the classified topic.
stevasaurus
Yes, if you can not return it, use our Classified For Sale Section to sell it.  :occasion-xmas:
  • Similar Content
    • giant_g2
      By giant_g2
    • Doug B
      By Doug B
      Hey guys,I have a dilemma I need some help with. I have a 1969 GT 14 that I replaced the transmission and pump on. For about 2 weeks afterward everything worked great, but while mowing at a pretty good pace I noticed a shudder and the tractor slowed a little but not bad. The more I rode it the slower it got until it barely moves. What stumps me is the hydraulics are still very strong,as in I can back the 3 point under the bumper of my truck and if you lift the arms all the way up the front wheels of the tractor will clear the ground. Have checked the tow valve and checked the internal filter,but no luck. I have also checked and replaced the forward and reverse bypass springs and the lever is moving the cam to full travel, forward and reverse. Any help would be appreciated.
    • mattd860
      By mattd860
      I have developed a kit that allows a Wheel Horse / Toro hydrostatic tractor to be operated by a pedal on the right side of the tractor. The original forward/reverse lever can be retained or removed. The kit includes everything needed to install the pedal kit and installation is simple with the help of a downloadable installation manual. Additionally, only one (1) 1/4" hole will need to be drilled which can be done by a hand drill. No other drilling or cutting will be necessary. Any tractor with this kit can be converted back to stock without any visible evidence that kit was installed. However, you'll never want to do that
      The kit operates very simply and similar to modern tractors. When the pedal is pushed forwards the tractor will move forwards. When the reverse pedal is pressed downwards, the tractor will moved in reverse. If the operator takes his foot of the pedal at any time, the pedal will automatically center itself and the hydrostatic transmission will return to neutral (stop). This enables the operator to use both hands on the steering wheel or one hand on the wheel and the other operating an attachment like a snow blower, plow, etc.
      The foot pedal is custom cast in Aluminum, uses brass bushings to minimize wear, and it closely matches the OEM Wheel Horse BRAKE pedal commonly found on 8-speed manual transmission tractors. Modifications were done to the pedal to add the reverse pedal and adapt the pedal to the rest of the kit. For the most part, the pedal looks like it was designed and manufactured by Wheel Horse / Toro. Additionally, a grease fitting has been adapted to the pedal to further minimize wear and tear and if the brass bushings ever wear out they are fully replaceable without having to buy a whole new pedal.
      The pedal kit fits the following series tractors with Eaton hydrostatic transmissions: C-1X5, 300, 400, 500.
      My kit can be adapted to older hydrostatic tractors with the Sundstrand transmission, however, you will need to find an updated hydro cam commonly found on ebay. Message me for more information.
      Here is a link where you can download the installation manual: CLICK HERE
      I am selling these kits for $330 shipped to anywhere in the United States. I offer multi order discounts as well. I will also sell to other countries for additional shipping charges to be determined.
      If anyone has any questions please feel free to PM me or post your question here and I will be glad to help. Or you can email me at mattdarling02@hotmail.com.
      Thanks!
      Below are pictures of the complete kit and the pedal installed on the tractor. Some modifications have been made since these pictures were taken. For example, the reverse pedal is now cast in aluminum instead of the steel pedal shown below.
    • Dylan2342
      By Dylan2342
      New here! hello everyone! In a bit of a pickle here. My father owns a 1993 (I think that is the right year) 520H Wheel Horse. I don't commonly work on tractors but it seemed simple enough. the axle snapped on the left side, so it needed a new transmission. My dad bought a used transmission and I went to work changing everything out. The hydraulic pump that the engine's drive belt attaches to went to a different model/year of tractor, so I had to remove that part and swap it in from the old transmission. In the process I lost all of the oil in the pump (I mention this because I wonder if it has to do with my problem I'm having). When I reassembled everything I started the slow process of filling the transmission. I filled it up and started the engine. When moving the lever forward or backward, it had a tiny bit of power for a little bit and then lost power. The transmission wasn't doing anything, anymore. I though maybe that hydraulic pump needed to be primed, so we took the top hydraulic line off of the hydraulic pump right above the drive belt and used a transfer pump to pump some oil into the pump case. This still didn't work. I don't have enough experience with these hydrostatic transmissions to know if we got a bad transmission or if there is something obvious that I am missing when it comes to a transmission swap. I ask for any insight and help please. If you need pictures or any other info, then let me know what you need. Thank you!
    • Porkskin
      By Porkskin
      I have no understanding of what it is like to push one of these when the trans is disengaged and motion lever is in the forward position as the manual mentions. I hope this is not old ground and that I am not cross posting. With the trans disengaged and motion lever set forward there is still something spinning in and about the transaxle that is giving resistance. I need to know if this is normal or if I should be expecting more of a free wheeling experience. In effect, much less resistance. Thank you for comments or pointing me to a topic that already covers this.
