kudzu3
What do you use...
kudzu3
to replace the dash housing tape? Parts viewer list it as part # 5606 (tape) but it is dis continued. What will be good to replace it with? Thanks
tunahead72
Not sure what kind of tape you're referring to...  What tractor are you talking about?
rmaynard
If you are referring to the edge protector on the dash housing where the hood contacts it, I use the fuzzy part of a self adhesive Velcro strip. It can be applied to either the dash or the underside of the hood.
Sent from my Moto G using Tapatalk
squonk
McMaster-Carr sells it. It's like a door edge moulding. The exact name escapes me. Plastic & rubber edge moulding with a metal core
Edited by squonk
Trouty56
Squonk...are you thinking of trim-lok????
kudzu3
Yes, I am talking about the area where the hood contacts the dash, shoulda been more clear, sorry. The tractor is a B 80. Maynard, the Velcro sounds like a good idea, I may try that. Squonk, I will also check out the McMaster Carr product, thanks all!
rmaynard
Lowe's sells the Velcro in 3/4" wide strips in black and white. I apply it to the underside of the hood.
Wishin4a416
If you have an old seat laying around, you can use the edge banding from that.
