whanna
Wheel Horse Tubes and Tires
whanna
I need a tube for a my B-111 front tires. They are all dry rotted, and leaky. The tires are Carlisle Turf Saver 13x6.50-6 tires. Any suggestions, I am having a hard time finding a good match for them.
Thanks,
Liam
whanna
What valve stem style would I need?
Racinbob
With tubes I personally like the threaded type stem that stays into place even at low pressure. Either type will be fine though.
JC 1965
The threaded valve stem is the way to go. :twocents-02cents:
whanna
Would that be the tr-87 or the tr-13?
Racinbob
I don't think either. I believe those are just metal stems but not held in place with nuts. Here's what I use. Tough to get a good shot but you get the idea. These won't push back in the tire if the pressure is low..
post-8408-0-54284100-1403276105_thumb.jp
Racinbob
Found this. Like a TR-4 or TR-6. This doesn't show it but it's incorporated into the tube.
Racinbob
Here's a better pic.
whanna
I gotcha. The website I was looking on doesn't seem to have any with those stems. Is there a website or dealer you prefer?
Racinbob
I found mine on Ebay. They are made by Kenda but I'm sure there's many others too. They are a bit pricier than the 'normal' tubes but I think worth it. I paid about $20 each.
ol550
Be carefull putting tubes in those dri-rotted tires.  They try to get back out.
  • Similar Content
    • Jon Paulsen
      By Jon Paulsen
      Inexpensive - Carlisle X Trac ATV Bias Tire - 16x6.50-8 Good quality (I expect) Should look nice with my large rear aggies
      I don't know how much these have been discounted, but I expect anything you find like this from a good brand will be 2X to 3X the price. $45 each at Amazon. This tire is discontinued.
      Rough measurement seems they are about 16" tall and the lugs are about 1/2" deep.
    • Blackhood Bill
      By Blackhood Bill
      Ok guys have a question will a 23 x 10.5 x 12 fit. I currently have 23 x 9.5 x 12 tires on my horse.
    • Patrol D-6
      By Patrol D-6
      Hello,
         Does anybody have any information on NOS TORO PART NO. 112773 TUBE for the Tie Rods ????  These are discontinued.
    • mr_speegs
      By mr_speegs
      After consulting the forum and trying to fix something on my own, here I am...
      My 876 got a flat in one of its front 16x5.50-8 tires (originals). The tube was not salvageable and I know that this particular tire/tube size hasn't been manufactured since the 1970s. I tried using a 16x6.50-8 tube in the tire but probably ruined it due to wrinkling/pinching. So now it's flat again. Short of getting all new wider tires and thereby longer spindles too, does anyone have any suggestions? My Horse is a worker and the original front tires are perfectly serviceable, so I'd like to keep costs down.
