04, Two Piece, Black with black pleats seat covers, NEW PRODUCT
By
Fun Engineer, in Wheel Horse of Michigan
Similar Content
By rustyedge1
Looking at this Ferris seat and wondering about the issues I may encounter in trying to switch out entire seat on the 417 or even if it can be done ?
Any info would be appreciated and thanks in advance.
By Monstrosity
Show off what your doing from the seat of your Horse!!! Fixed up a mowing deck for the 1277 and put the plow on the C1014. Getting ready to level a topsoil pile and going down the block to mow the small park to test the mowing deck out.
By Bach-Ed
I need a little part number help. I'm looking for the part number of the idler pulley that tensions the drive belt on my 857. The diagram shows the left side of the tractor. And I can't seem to locate the pulley on the parts drawing. The bearings have gone out on my tractor's idler.
By Bach-Ed
I needed to disassemble the brake/cluch linkage on my 857. Am I missing something or do 2593 Clutch Rod, 5544 Parking Brake Lever and 3935 Brake Rod all need to be in place on 4899 Clutch Rod Pivot Arm before I can struggle to align the holes with that of the 3950 Idler Arm Shaft to insert the roll pin? I'm using up all my naughty words trying to get this back in place. I'm hope someone can suggest a better way. Or all you can do is extend your sympathies?
