Crabtreeb
B 80 Rebuild
Crabtreeb
I am rebuilding a 1974 B80 with the 5084 tran axle is there any one out there who knows the cross over numbers for the seals, bearings,gaskets, any help will be great fully appreciated.
AMC RULES
:WRS:
  Maybe this will help.  :handgestures-thumbsup:
rmaynard
Just did a 4 speed and the Toro and generic part number are:
1" Axle seals and brake shaft seal, Toro #100863, generic CR-9815
Input shaft, Toro #100441, generic CR-7410
Gasket, Toro #3912
Crabtreeb
Thank you both any one got the numbers on the needle bearing fot the axle i don't see my trans in the PDFs allso how do you become a financial supporter of this site it has bin verry helpful.
rmaynard
At the top of the page is a section called "store". You can purchase your membership there.
The axle needle bearings are Toro #1528. They cross to a Torrington B-1616.
stevasaurus
You want the PDF #2 which is for 3 and 4 speed transmissions.  :)
Crabtreeb
Thanks for all the info this is such a great site.
