KC9KAS 4,741 #1 Posted May 26, 2014 I have several implements that have a sleeve/clevis hitch mount, but do not have any horses with the sleeve/clevis hitch, so I have been collecting/preparing to build an adapter. I have attached photos of my adapter, but please refrain from laughing out loud at my welds! I can weld pretty (won't hold) or wooly looking (holds tight) so I go for strength!! 4 Share this post Link to post Share on other sites
squonk 41,016 #2 Posted May 26, 2014 Looks good. I have a homemade one with a longer tongue than yours and an OEM Brinly with even a longer one. Should do the job.nicely. Share this post Link to post Share on other sites
JUSS10 250 #3 Posted May 28, 2014 So did you drill a hole so a pin can go all the way through the tube or just leave it un drilled? looks good! Justin Share this post Link to post Share on other sites
KC9KAS 4,741 #4 Posted May 28, 2014 So did you drill a hole so a pin can go all the way through the tube or just leave it un drilled? looks good! Justin Yes, I drilled all the way through the steel. I may have made the tongue part a little short....one of the bolts may hit the cable lift attachment point on the slot hitch. I haven't tried it as of this time. Guess we will find out later today! 1 Share this post Link to post Share on other sites
AMC RULES 37,125 #5 Posted May 28, 2014 Turned out really nice... look just like factory welds. Share this post Link to post Share on other sites
