KC9KAS
Was Busy Today
KC9KAS
I have several implements that have a sleeve/clevis hitch mount, but do not have any horses with the sleeve/clevis hitch, so I have been collecting/preparing to build an adapter.
I have attached photos of my adapter, but please refrain from laughing out loud at my welds!
I can weld pretty (won't hold) or wooly looking (holds tight) so I go for strength!!
  • Like 4
squonk
Looks good. I have a homemade one with a longer tongue than yours and an OEM Brinly with even a longer one. Should do the job.nicely.
JUSS10
So did you drill a hole so a pin can go all the way through the tube or just leave it un drilled? looks good!
Justin
KC9KAS
Justin
Yes, I drilled all the way through the steel.
I may have made the tongue part a little short....one of the bolts may hit the cable lift attachment point on the slot hitch. I haven't tried it as of this time. Guess we will find out later today!
AMC RULES
Turned out really nice...  :handgestures-thumbsup:
look just like  :wh: factory welds.
