JC 1965 1,530 #1 Posted May 17, 2014 Just noticed the brake shaft seal on my 1991 312-8 is leaking. I purchased the seal ( # 100441 ) but now I can't get the brake drum ( cylinder ) off. I can remove the bolt but the drum is frozen in place. I tried using a puller but it won't budge. Anyone have this problem before ? Any help would be greatly appreciated. Share this post Link to post Share on other sites
whfan74 2,068 #2 Posted May 17, 2014 Have you put heat to it yet? Get her nice and hot while the puller is on it to keep some pressure on the drum itself. Share this post Link to post Share on other sites
Kelly 1,029 #3 Posted May 17, 2014 I had one I had to heat over and over again with a big 3 jaw puller on it, in the end I trashed the bearing in the case with to much heat. Share this post Link to post Share on other sites
JC 1965 1,530 #4 Posted May 18, 2014 I had thought about using heat but was afraid I would damage bearing or other seals. I guess I will have to try the heat cause it isn't coming off with the puller. Thanks guys for your help. Share this post Link to post Share on other sites
Racinbob 11,238 #5 Posted May 18, 2014 There have been times when I've had to soak the part for days. I use PB Blaster. The most recent was a flywheel on a K91. After a couple of weeks of soaking (I was in no hurry) it finally popped off. In your case, fill the set screw hole up with the penetrate too and just leave it while. 1 Share this post Link to post Share on other sites
DanPatch 6 #6 Posted May 18, 2014 I also use the soak it for days method. I use liquid wrench and I apply just enough heat (to the part I want off) to get the liquid wrench to bubble. I have a wheel hub that that I am trying to get off I fill the set screw hole, heat the hub until the liquid bubbles. I have done this three times this week. the level of liquid in the hole is finely starting to drop when it sits overnight. I am using a big puller but I don't want to brake the hub. The other hub came off with this same method. Share this post Link to post Share on other sites
JC 1965 1,530 #7 Posted May 18, 2014 Thanks guys, I'll try the soaking method also. Share this post Link to post Share on other sites
Lane Ranger 10,992 #8 Posted May 18, 2014 (edited) Seaform's Deep Creep is another good soaking product. Sometimes works faster than PB Blaster for me! Edited May 18, 2014 by Lane Ranger Share this post Link to post Share on other sites
meadowfield 2,595 #9 Posted May 19, 2014 I've started using the welder on things like this - brake drums, hubs, trackrod ends. Just crank it up and weld to a piece you either don't care about or can grind off. It's faster and easier than trying to apply heat from a blow torch. It's amazing how quick things fall off Share this post Link to post Share on other sites
JC 1965 1,530 #10 Posted May 20, 2014 Thanks for all the help guys. I still haven't got the brake drum off yet but If I get lucky and it comes off, should I put any kind of lubricant on the seal ( grease etc. ) before I install it. This will be my first seal replacement attempt. Share this post Link to post Share on other sites
Racinbob 11,238 #11 Posted May 20, 2014 I just put a light film of oil on it. Make sure the shaft doesn't have any nicks or burrs on it. Pay close attention to the keyway slot. You don't want to damage the seal as you slide it on. A 3/4" washer and a short piece of pipe will help you tap the seal in place. Share this post Link to post Share on other sites
JC 1965 1,530 #12 Posted May 21, 2014 I just put a light film of oil on it. Make sure the shaft doesn't have any nicks or burrs on it. Pay close attention to the keyway slot. You don't want to damage the seal as you slide it on. A 3/4" washer and a short piece of pipe will help you tap the seal in place. Great info, thank you !! Share this post Link to post Share on other sites
