By
mikekot3
Hello
I want to buy the seat mentioned in Martin Howard's 416 adventures. I tried to contact him but he is not able to receive emails through red square.
I have a 1993 WH 416-8 tractor. He used a KM UNIPRO 123 seat from www.turfseats.com
Which seat switch do I use on the replacement seat? My used my FLUKE 88 dvom in auto ranging mode to test the original seat switch. With the
seat switch disconnected I get a ohm reading and O.L when I sit on the seat. I am thinking that tells me
that the seat is Normally OPEN. Am I correct in this? Did the KM seat switch come with a pigtail for wire it up?
If not how do I install the switch? Where did you get the seat rubber bumpers for the swing up seat base? I believe they were black or grey.
Also I installed a Briggs and Stratton Vanguard v-twin 23 hp engine swap kit from small engine warehouse.
The hour meter does not work any more after replacing the swapped in engine. I was thinking that a aftermarket hour meter/tach from esitest.com would
work. http://esitest.com/329.html
My other question is that I can only start the tractor by turning the key and also turning the light switch ON to engage
the starter motor. I am thinking one of the power wires in the white AMP engine harness connector is in the wrong pin position as I had to
replace the connector.
Please advise,
Michael Kotarba
mkotarba@hotmail.com
