cmckella 0 #1 Posted May 9, 2014 (edited) Ive been chatting Steve from the forum over skype the last little bit, along with a few other guys briefly. I want to thank everyone so far for their help. I was having some issues with my 5010 transmission (had no forward drive) only reverse worked. So I was chatting to Steve and he explained to me what to look for. Anyways I got the trans apart and took a lot of pictures. I will post the worst ones below in the thread. I will be looking for parts or a complete transmission judging by the amount of damage in the transmission Pics below Right side of the transmission case. Axle stub/housing snapped off the case casuing the axle to float around Left side of the case- brake band snapped off Right side of the case- internals (bearing and race destroyed) Left side of the case. One bearing has nothing left in it One of the gears (im guessing maybe the input gear?) Differential- Had a bunch of teeth laying the the bottom of the transmisson housing Pinions- not looking good on either side Bit of wear on this gear too Inside of the case I know thats a lot of pictures, just trying to see if anything is salvagable. I can take more pics if needed too Edited May 9, 2014 by cmckella Share this post Link to post Share on other sites
Racinbob 11,378 #2 Posted May 9, 2014 WOW! Maybe remove the shifter and install a new transmission under it? Seriously, I'm nearing the completion of fixing up my 5010 and I had some issues but nothing like that. There's many folks her that can help you and Steve is one of the best. He was a great help to me. I'll be watching this thread to see what the prognosis is. Share this post Link to post Share on other sites
stevasaurus 22,956 #3 Posted May 9, 2014 (edited) Welcome to Red Square Chris...Excellent pictures!!! I kind of think Bob hit the nail on the head...you have a lot of paper weights there. I have not seen one with that much damage...unreal. We need to find you another trans. I would bet you can almost poke your finger through the worn out spot in the casting. Some of those bearings may be OK though. The ones with 8 like 1/4" balls are your open S8K bearings. The other ones are closed NICE 412-35 bearings. The gears on both ends of your cluster gear looked OK. Yes, that is the input gear as you stated....it has some wear, but may work. That is about all that is OK. The roll pins, holding the differential together, look great... Sorry...my bad. Don't throw anything out. Tap out those roll pins in the differential...those pinions (or spider gears) are on posts. Those posts are probably OK. Tap out the roll pins in the axles (inside the differential)...the axles should pull out of the axle gears...those gears may be OK. Did one of the axles break? Fantastic pictures. Edited May 9, 2014 by stevasaurus Share this post Link to post Share on other sites
stevasaurus 22,956 #4 Posted May 19, 2014 Found you a 5010 transmission Chris...from SmokinJoe... Share this post Link to post Share on other sites
Racinbob 11,378 #5 Posted May 19, 2014 Cool Steve. I see that you managed to get the hubs off without resorting to the universal fail-proof hub removal tool. 1 Share this post Link to post Share on other sites
stevasaurus 22,956 #6 Posted May 20, 2014 I did have to use the puller on the hubs, input puller and the brake drum, but they all came off easy. What gave me the problem, for a day, was that brake lever system with the small roll pin in it. This had about 1 qt of water and about 1/2 qt of tan oil, but no lumps. I drained it good...added about 2 qts of diesel and ran her in all gears for a total of about 1/2 hour. The seals didn't even leak. Drained it out and from what I can see...she looks brand new inside. It is easy to get all the diesel out when you have the trans on a bench. 1 Share this post Link to post Share on other sites
squonk 41,741 #7 Posted May 22, 2014 Keep the diesel out of the Beard! Share this post Link to post Share on other sites
stevasaurus 22,956 #8 Posted June 2, 2014 Chris...the trans is getting shipped out tomorrow morning...(Fastenal) $60 from me to West Seneca, NY...should be there next Tuesday 6/10/14...they will call you when it gets there. Skype me. Share this post Link to post Share on other sites
