J-Bore 0 #1 Posted May 8, 2014 The hydraulic deck lift cylinder is leaking oil onto the mower deck belts causing them to slip. Can I plug the ports for the hoses from the HydroGear trans to the deck cylinder as a temporary fix to keep mowing? Thanks for any help. Share this post Link to post Share on other sites
oldredrider 2,548 #2 Posted May 10, 2014 Not sure if you can plug the ports without removing the cone valves. PM me...I think I have the parts you need to get you up and running. Share this post Link to post Share on other sites
