HorseFixer 2,014 #1 Posted May 7, 2014 (edited) I had a little time in the garage a week ago, and had the fixins to weld this together. Just pull or insert the bolt Though the mounting bracket and Gen for easy on or off you don't even have to tighten a nut and it holds just fine. I was thinking about having a battery Jump pack with a mounted start switch with test leads hooked up but either way This will come in handy to ck the output of Delco Starter Generators when they are off the tractor. I was gonna post some crap that they were given to WH Dealers for their repair shops but figured you guys would know better. So as Lars would say..... what the folck! ~Duke http://youtu.be/Kafd8pw1bGQ Edited May 7, 2014 by HorseFixer 1 Share this post Link to post Share on other sites
AMC RULES 37,254 #3 Posted May 7, 2014 Straight from the Duke Ponds factory. Share this post Link to post Share on other sites
buckrancher 2,696 #4 Posted May 7, 2014 (edited) I don't think that will spin them fast enough duke to use it as a check stand you need about a 3 to 1 ratio Brian Edited May 8, 2014 by buckrancher Share this post Link to post Share on other sites
prondzy 3,889 #5 Posted May 8, 2014 That's awesome! I am currently in the works for making a growler to test the armatures for shorts. Share this post Link to post Share on other sites
