jackhammer
Curious about the 418 ??
jackhammer
Looking thru the model years I noticed the 418 only was made for 1 year .
Members with the resources might be able to fill in these  2 questions ,,  About How many were produced ??
and  for what reason would you think production was limited to 1 year. ???    :confusion-scratchheadyellow:
Thanks
jackhammer  :tools-hammerdrill:
Rick
Edited by jackhammer
dennist
I can't answer your questions, but the 418 is one of my favorites for sure. The last one I had was very clean well kept and I used my tiller with it. That thing was so smooth and sounded great, I am always looking for those.
520HC
Lots of Wheel Horse models were only produced 1 year.
rexman72
417s were produced in 2 years
leeave96
I think (I think) the switch to Onan ended the Kohler Magnum twin run in the Wheelhorse.  I'd say a 18 hp Magnum twin powered Wheelhorse would be one of the great combo's Wheelhorse ever made.
  • Like 3
darg
I think the 418 is the same as the117 except the engine name.
very fine tractors
darg
JackC
Wheel Horse switched to ONAN engines in 1988 because they had more torque at lower RPM which was needed for the big 60 inch decks under the 520 Series tractors.
jackhammer
Thanks for the replies guys.
Any other differences ?
That's pretty much what I thought but am not schooled enough on the subject to really understand why. The 417A  I have has aluminum heads -  does the twin cylinder 18 have alum or cast with the magnum . Axles front and back any different or are they the same on both ?? just curious .
darg
The 418A that I have had the kohler mag 18 with alum  heads and case. I  think the axles are the same as the 417, but not fore sure.
darg
