richmondred01
520 no electrical power
richmondred01
520h was running fine then started over charging. That lead to the 30 amp fuse melting down. Got the 30 amp fuse out and replaced it. Now there is no power at all not even for the lights. Where should I start looking?
Ed Kennell
Check the battery , then the B terminal on the ignition switch. To melt the wire to the 30 amp fuse, you must have a dead short to ground. Did the drive belt get against the wiring harness and wear it thru ?
slammer302
Had that happen to me and it ended up being the ignition switch went bad
Save Old Iron
You may (probably) still have corrosion inside the fuse holder on the electrical contacts
Although a direct short will take out a 30 amp fuse, the fuse element will blow or vaporize instantly. If the fuse body has melted, this indicates PROLONGED high temperatures near the fuse body, most likely from a high resistance in the fuse socket.
The heat formed by the current running thru a resistance in the socket heats the socket and melts the fuse.
Remember, a 50 watt soldering iron can generate 700+ degrees and draws less than 1 amp of current. So its not likely a simple overcharge issue will melt the fuse.
Recheck the fuse holder terminals.
Edited by Save Old Iron
