kcuttuck
C 141 High/Low range
kcuttuck
I have a C 141 with the 3 speed with reverse and high and low range. The shift leaver for high/low range moves and it feels like it goes from one gear to another but the speeds don't seem to be any different. any suggestions? In low range 1st gear it seems a little too fast for tilling. I would think it would be just crawling.
Lane Ranger
You could have an issue with the low ranger shifting fork.   There is a section in the Transmission  manual on the high-low  transmissions for C models that will give you some pointers.   Check in the transmission section of Red Square.
kcuttuck
Thanks, I'll check it out.
stevasaurus
Yep, it should crawl if you are in 1st gear low.  If it is a slow walk, you are probably in 1st gear high.  Most likely it is the shift fork and this requires opening up the trans to fix.  The parts are available and not real hard to do.  :)
  • Similar Content
    • giant_g2
      By giant_g2
    • wh315-8
      By wh315-8
      This is a tag on a 1970 Raider 10 from someone on a FB group. Never seen one that had USED on it, it is Model 1-6041 U
                Serial  342 USED.
      owner thought tag reads 2-6041 U for model but not sure.
      I just wonder if this was perhaps a warranty factory return and they used a new id tag this way?
      Anyone ever come across something like this?
       Typed in the numbers for Clarity.
    • cbj75
      By cbj75
      I have a 1975 D200 Wheel Horse with front mount dozer blade, package includes Wheel Horse Dump Trailer, 48" belly mower side discharge, Wheel Horse front and rear wheel weights, turning brakes, rear PTO and 3-point to 2" receiver attachment, and Brinley twin disc harrow. Rear luggage/rack carrier, All refurbished, sandblasted and painted Ford red in 2016. Lots of extra Wheel Horse parts included.
      Package price $3000.00.
      Bryce Johnson
      102 Anglers PT
      Mc Cormick SC 29835
      913-638-6788
      IMG_1962.HEIC IMG_1965.HEIC IMG_0279.HEIC
    • sjoemie himself
      By sjoemie himself
      Hi all, as mentioned in another topic I visited the local harvest-show in Onstwedde again. I brought my mini International 1468 with me and got set up at around 9 in the morning. Gates opened at 10.
      It was a bit overcast and wet at the beginning but it turned out to be a nice and sunny day for the most part.
      @Pullstart requested some show pictures so here ya' go
      All set up, waiting for the folks to come in and say Hi.
      This 1/3rd scale stationary thresher is built by my dads grandpa (who has passed away) and is now owned by my dad's uncle.
      He tours the country with it and displays it on several shows. It actually works and my dad's grandpa used it to harvest beans.
      The steam tractor that powers it is not my dad's uncle's but happened to be there aswell so they thought let's see if the tractor can power the thresher. Worked flawlessly.
      Besides the small tresher there's always a real one setup aswell. They thresh grain and bale the straw with the attached baler.
      Powered by a flat belt off a vintage Hanomag tractor.
      Threshing machine, Dutch built out of the province of Groningen.
      Straw baler. The bales are manually tied and knotten.
      This apparatus was placed before the thresher. Not 100 percent sure what it does but it seemed it gets rid of excess chaff and other unwanted debris.
      Who can guess what these are and/or what they're used for?
      Vintage DAF truck. Dutch truck brand. This one was very nicely restored.
      And another one, this one obviously for military use. Note the second axle which is free rolling. This helped it conquer dunes and tranches in rough conditions. My granddad used to operate one of these.
      Also no big center differential on the back axles but driveshafts coming directly from the main gearbox. The shock is the rear of the vehicle. I guess they went this route for maximum ground clearance and articulation.
    • Monstrosity
      By Monstrosity
      Show off what your doing from the seat of your Horse!!! Fixed up a mowing deck for the 1277 and put the plow on the C1014. Getting ready to level a topsoil pile and going down the block to mow the small park to test the mowing deck out.
