By
Metal Blender
My 312 hydro has the 12hp kohler motor,It has 3 wires white,purple and orange coming out from the stator area but the orange is not hooked up.The stator test around 40 volts ( multimeter test) but the battery is not charging.The regulator is cheap but new (not OEM).My question is the orange wire,what is it for? If I should hook it up? If yes then to what should it be run to?Battery +?. My regulator test was a failure but the tractor runs fine besides de-charging.Im searching for alternative reasons for the regulator not working other than its no good.Like cleaning and refitting all ground connections,cleaning and refitting the battery terminals and connecting wires.Is it posable the ignition switch is the wrong one or is failing at one or more poles? Thanks for any help
