Gwtaylor 1 #1 Posted April 22, 2014 Just aquired a B-111 wheel horse in need of full restro Problem is I know nothing about them where to get parts from the age or anything So team any comments good or bad welcome and any info on the beast such as parts missing add on's who does spare body parts Thanks Gary Share this post Link to post Share on other sites
meadowfield 2,650 #2 Posted April 22, 2014 Welcome Gary, you've come to the right place! It's likely to be circa 1979, can you locate the ID plate and share the model number? That helps with manuals, etc. Though we've had a few of those, Briggs 11hp, foote 6 sp box. Good little tractors they are... Looks relatively intact, does it run? Mark Share this post Link to post Share on other sites
Gwtaylor 1 #3 Posted April 22, 2014 Hi It's still in the yard where I saved it from the scrap heap as it was about to get weighed in as scrap I pick it up tomorrow morning so I'll have more pictures then and to see if it starts. Main problem rear axle it's snapped don't know how or why it snapped but I'm assuming a rear axle for one is going to be hens teeth? Share this post Link to post Share on other sites
Sparky-(Admin) 22,019 #4 Posted April 22, 2014 Mike........... Share this post Link to post Share on other sites
meadowfield 2,650 #5 Posted April 22, 2014 Hi It's still in the yard where I saved it from the scrap heap as it was about to get weighed in as scrap I pick it up tomorrow morning so I'll have more pictures then and to see if it starts. Main problem rear axle it's snapped don't know how or why it snapped but I'm assuming a rear axle for one is going to be hens teeth? That flavour axle is tricky, you say snapped... Both wheels look intact and inline. Sometimes the circlip on the inside of the tranny can be broken off causing the axle to slide out. It might just need some tlc - unless of course the casing itself is broken :o Share this post Link to post Share on other sites
AMC RULES 37,145 #6 Posted April 22, 2014 l'll bet you'll be suprised...at the parts that are out there. The universe will come to your aid. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,235 #7 Posted April 22, 2014 Foote transmission service manual Transmission parts list http://www.wheelhorseforum.com/files/file/3517-transmission-gear-foote-6-speed-4000-iplpdf/ Tractor manual Will get a tractor parts list uploaded and post when I do. Garry Share this post Link to post Share on other sites
Gwtaylor 1 #9 Posted April 23, 2014 Foote transmission service manual Transmission parts list http://www.wheelhorseforum.com/files/file/3517-transmission-gear-foote-6-speed-4000-iplpdf/ Tractor manual Will get a tractor parts list uploaded and post when I do. Garry Thanks for that Great job Share this post Link to post Share on other sites
Amanda 81 #10 Posted May 6, 2014 Welcome to red square!! Share this post Link to post Share on other sites
