rj24 38 #1 Posted April 17, 2014 i have a eaton 1100 hydrostatic transmission and i have air in the lines and i need to know how to get it out or will it work its self out after time i gust rebuilt the trany and had to tack off the oil lines so there was no oil in the pump Share this post Link to post Share on other sites
bmsgaffer 2,065 #2 Posted April 17, 2014 I believe the eaton manual states to just run the system for a few minutes to warm up then raising and lowering the lift system (keeping an eye on the oil level) for a bit. Top up the oil to the right level when you shut it off. Share this post Link to post Share on other sites
varosd 1,185 #3 Posted April 17, 2014 I believe the eaton manual states to just run the system for a few minutes to warm up then raising and lowering the lift system (keeping an eye on the oil level) for a bit. Top up the oil to the right level when you shut it off. After changing my Workhorse hydro hoses, I put it up on jack stands and warmed up the engine (without the tranny engaged) then engaged the tranny and sure enough the tires really didnt move so I shut everything down and added oil and repeated until all was good! you shouldnt have to bleed or burp it. Share this post Link to post Share on other sites
rj24 38 #4 Posted April 17, 2014 ok thanks but i have a whining nice and it was not there befor i fix the trany and when you pull the dip stick out theres a lot of air bubols on it Share this post Link to post Share on other sites
varosd 1,185 #5 Posted April 17, 2014 gasket leak? Is it leaking anywhere? Share this post Link to post Share on other sites
rj24 38 #6 Posted April 18, 2014 no its all dry no leaks at all now so i'm good to go on that Share this post Link to post Share on other sites
bmsgaffer 2,065 #7 Posted April 18, 2014 I think the air bubbles come in if the fluid level was too low and the pump sucked up some air. I would change the oil in the transmission again (now that you should have oil circulated in the system, the level wont drop as much when run) to get bubble free oil and make sure it is full to to top of the the dip stick. Maybe even try turning the pump by hand for a while after the new oil to let some oil circulate without sucking in air? **top of the full line on dipstick...NOT the entire dipstick... if that wasnt clear Share this post Link to post Share on other sites
rj24 38 #8 Posted April 18, 2014 ok thanks i have a ? i was told it tacks 5 qut of oil but it only as 4 in it and it sead it full but when its on a hill side ways it seads it low is there a way to fix it Share this post Link to post Share on other sites
bmsgaffer 2,065 #9 Posted April 18, 2014 Well whenever you are on a hill all of your fluids will probably read wrong. I think it takes 5 qts if the system were completely empty, but there is always some residual fluid in the system when you change (filter, lines (even though you changed them), pump, etc) Share this post Link to post Share on other sites
