hondagod64
73 Auto Transmission Filter and Fluid
hondagod64
I just purchased a 1973 Auto Wheel Horse tractor with a 12 hp Kohler and I'm looking for information on a replacement transmission filter and what kind of fluid should I use....????????
squonk
Fluid may be motor oil or Automatic trans fluid. Oil is gold Trans fluid is red. Use a Napa 1410 filter. Better and cheaper than a Toro filter. And if  you don't believe me,cut em open and see for yourself.
hondagod64
First thanks for the quick reply, and the fluid is red in color...would you suggest a certain brand or kind of trans fluid such as dextron or a straight atf fluid?
squonk
I would use synthetic Auto trans fluid or flush out all the oil (Time consuming) and switch to Mobil 1 10W 30
