Swemill
Action pics with loader!
Swemill
Some new pics with my father doing some work for me with the D-180.
Must say that it’s a true work horse and it did a great job! It moved a lot of heavy road material this afternoon and actually even ripped up the asphalt with the new tires at some places! =)
27 x 8.5 -15†Skid Steer tires at rear on 7x15†rims and 4.00 x 10†at front on 3.5x10†rims and homefabbed hubs. I have now also connected the hydraulic pump under the tractor to the pto with a driveshaft. Works really well and I can still also use the pto at the front!
Next project on this tractor is to fix a foot-hydro control. That would be a great thing together with the loader!
  • Like 6
Tankman
That's a handsome Stallion. A work Horse!
Thank you for postin' the pic's!   :)
HorseFixer
Nothing like a Big D at work!
~Duke :wh:
AMC RULES
Interesting bucket design...
Hodge71
Seems to me you would really need to run high hydraulic pressures or you wouldn't be able to dump a fully loaded bucket. I would think there wouldn't be enough leverage
KC9KAS
Nice looking D and loader.
Thanks for the photos.
Swemill
How much do you mean with high hydraulic pressure?I understand your reflection hodge71, but that has not been any problem at all and it handles a full bucket very well.
Dont know what pressure i have but the loader needs 120 bar (1740 psi) to fully work and handle 500kg / 1100 Lb.
speedyleedy
Them are some awsome picture's thank's for sharing ! :)
  • Similar Content
    • BuffaloD200
      By BuffaloD200
      Hey all, I need to install a drive belt on my 75 D180 for my snowblower.  I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure.  The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell.  Do I have to remove the PTO pulley?  That seems to be a required service item.
      Same question for my 80 D200 as well really.
      Using the recommended 4L490W belt.
      Thanks
    • Redtickuleez
      By Redtickuleez
      Hello gentlemen!!! I recently bought a d180 with loader and backhoe. Im looking for serial number.. there is a plate under the steering wheel but its been pajnted over and i can make it out. Can y'all tell me another location and was this tractor pruchased originally with these attachments and any info would be greatly appreciated... Thanks fellow Wheel Horse enthusiasts !!! !! !!!
    • ihatephones
      By ihatephones
      I got a D-180 for $250, and the governor is messed up, the points won't open or close, and I took it apart and was being stupid and messed some stuff up in there, and now I need a new one.
      Where can I get one that's not on eBay for $200?
      I also forgot to say it was a Kohler K482, and I'll throw some pictures of the tractor in as a treat.
    • Southern_Secret
      By Southern_Secret
      Hello fellow Horse Heads long time no post for me, life gets crazy & a lot of things change sometimes but anyhoo. So back a few years ago when I first got my 1994 314-H I had it at my shop going threw it. One of my customers walk past as im working and said, you know I think Iv got a Wheel Horse & im thinking "no you dont buddy". I give him my # to send pics thinking it was a big waste of time & after getting the pics I realized he did have a Wheel Horse! I hand shake bought it right there, asked him to bring it to my store & he said no problem. Well after almost 2 years it is finally in my orbit. I know very little about it other than his father-inlaw got it new and used it around his house moving snow and stuff. His father inlaw moved down south here when his daughter got married and gave the tractor to my customer because he had a farm & his the inlaw had no use for it anymore. Same with every barn find, "it was running when parked" 8 years ago, said one of the axel seal is leaking. Im happy and hope I can get it back in running order soon cause it is going to be handy around the truck farm!!
      I will post Pics as soon as I reinstate my membership
