Swemill
Action pics with loader!
Swemill
Some new pics with my father doing some work for me with the D-180.
Must say that it’s a true work horse and it did a great job! It moved a lot of heavy road material this afternoon and actually even ripped up the asphalt with the new tires at some places! =)
27 x 8.5 -15†Skid Steer tires at rear on 7x15†rims and 4.00 x 10†at front on 3.5x10†rims and homefabbed hubs. I have now also connected the hydraulic pump under the tractor to the pto with a driveshaft. Works really well and I can still also use the pto at the front!
Next project on this tractor is to fix a foot-hydro control. That would be a great thing together with the loader!
  • Like 6
Tankman
That's a handsome Stallion. A work Horse!
Thank you for postin' the pic's!   :)
HorseFixer
Nothing like a Big D at work!
~Duke :wh:
AMC RULES
Interesting bucket design...
Hodge71
Seems to me you would really need to run high hydraulic pressures or you wouldn't be able to dump a fully loaded bucket. I would think there wouldn't be enough leverage
KC9KAS
Nice looking D and loader.
Thanks for the photos.
Swemill
How much do you mean with high hydraulic pressure?I understand your reflection hodge71, but that has not been any problem at all and it handles a full bucket very well.
Dont know what pressure i have but the loader needs 120 bar (1740 psi) to fully work and handle 500kg / 1100 Lb.
speedyleedy
Them are some awsome picture's thank's for sharing ! :)
  • Similar Content
    • tractorboy79
      By tractorboy79
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
