Bobie01
Hydro doesn't move 10 years
Bobie01
Hi I have a c-175 from belgium. Now this wasn't move more than 10 years and now I have to ask what I should do before I give force to the transmission. oil change is already made. Are there any other tips? thanks :)
Edited by Bobie01
petes
My first thoughts are was it stored outside, and if so was there water in the trans fluid. I would be ready for leaks as gaskets dry out and o-rings get hard after setting for that amount of time.  If you do operate it and everything seem ok, maybe a second fluid/filter change after some operating hour might be a good idea.
rmaynard
Does this model have a tow valve, and is it closed?
Edited by rmaynard
buckrancher
I think this one is a eaton 1100 no tow valve
gwest_ca
1981 operator manual
1982-1983 operator manual
Garry
woodchuckfarmer
Id take it slow and let it warm up good. Watch for leaks, run it around a little. Then if it seems ok run it.
Bobie01
it was store inside. thanks for the suggestion :) I will check it soon
