Adamsminitractor
What colour wires
Adamsminitractor
Hi i have just bought a HH100 engine and i need to wire it in. I have 1 green wire and 2 thick yellow wires. I belive the Green goes to earth for the engine kill but how do i wire the yellow wires for charging system. Thanks for you help all.
KATO
on both of my HH100 engines (1968and 1970 ) the "other two "(as mine are painted over)
wires for the charging system are wired to the AC terminals on the regulator and a green goes
from the DC out on the reg to bat + on the wiring diagram for my tractors ?? There may be a manual
for your Tractor in our manuals section...
http://www.wheelhorseforum.com/files/category/2-wheel-horse-manuals/
and :text-welcomewave:  to :rs:
  • Similar Content
    • bigcreek
      By bigcreek
      Well I found an eBay special, 700 Work Horse I bought for the deck to put on the 68 Commando I bought.
      This 69 came as a parts machine, but all that is there is in great shape. Already pulled the trigger on a Tecumseh HH10, unfortunately did not do the research prior about the crappy coils on these engines.
      Pill now ponder the repower more
    • Trouty56
      By Trouty56
      Service manual
      HH80, HH100, HH120, OH120-OH180, VH80, VH100
      First model year engines were named HH140, HH150 and HH160. Changed to OH140, OH150 and OH160 to reflect the overhead valves
      78 pages 1.60MB
      Tecumseh HH80-110112D used on
      1971 WorkHorse 800 model 1-0100
      Tecumseh HH100-115095B used on
      1968 Charger 9 model 1-7931
      1968 Charger 9 model 1-7932
      1968 Raider 9 model 1-6931
      1969 Charger 10 model 1-7041
      1969 Raider 10 model 1-6041
      Tecumseh HH100-115145B used on
      1970 Raider 10 model 1-6051
      Tecumseh HH100-115145C used on
      1971 Raider 10 model 1-0300
      Tecumseh HH120-120129C used on
      1970 Charger 12 model 1-7253
      1970 Raider 12 model 1-6253
      Tecumseh HH120-120180D used on
      1974 C-120 Automatic model 1-0495
      1975 C-120 8-Speed model 1-0357
      1975 C-120 8-Speed model 1-0375
      Tecumseh HH160-170019 or OH160-170019 used on
      1974 C-160 8-Speed model 1-0385
      Tecumseh VH80-148001 used on
      1970 Charger V8 model 1-7851
      1970 Commando V8 model 1-4851
      1970 Commando V8 model 1-4852
      1971 CG-8 model 1-0200
      1972 CG-8 Auto model 1-0200
      1972 CG-8 Auto model 1-0201
    • RedRider
      By RedRider
      I'm working on rebuilding HH100 and trying to be as attentive to details as possible with my restoration. The picture below was of an NOS Raider 9, which is very similar to the tractor I am working on. The piece in question is highlighted by the yellow arrow in the picture below. What is this metal hoop on top of the engine called and what is its purpose? I have seen some tractors with it and others without. It seems useless to me and likely to be discarded if someone ever rebuilt the engine. I can't seem to find a good reference to it in the online HH100 parts list, at least not anything that gives me a part number to look up. Any insight into this would be appreciated.
    • classiccat
      By classiccat
      As the title suggests, I'm at a crossroads for a '74 HH100 (10hp) cast iron tecumseh sitting on my shelf.
      It looks like it was once part of a generator or welder (seller's pic below).
      With a decarb, valve job, tank / carb cleaned and a new head gasket, it runs smooth, no knocks/smoke and has nice throttle response.
      The bore and ringgap are in spec.
      The only downside is that the crank is hacked off (I assume it was a tapered shaft anyway) and there's no keyway.
      What would you do?:
      Buy another crankshaft and possibly a connecting rod? Have a keyway milled in the existing crank and add a shaft adapter (1 1/8")
      Here she is getting acquainted with her cast-iron K181 cousin.
      I think she'd make a fine power plant for a wheel horse roller someday!
    • BenTheWheelHorseMan
      By BenTheWheelHorseMan
      I know I've been mia for a while, so it's good to be back. I was looking at a Massey Ferguson 10 on Craigslist, but it has the Techumseh HH100. I have had much better luck with kohlers and just so happen to have an extra K241 laying around the barn. I was wondering if you guys thought it would be super difficult other than the obvious ( changing wiring and ignition switches) to swap out the motors.
