varosd
Set screw/Non set screw Transmission Pulley
varosd
Any reason why some Tranny pulleys have a set screw and some do not?
The parts list for the Eaton 1100 on the Workhorse shows it having one but it doesn't have one. when I replaced the sheared off hydro fan bolt, I noted that the pulley (part # 108316) was migrating off the shaft.  I guess this is what caused the bolt head to come off.  I still had to use a gear puller to get the pulley off.
my 88 520 parts list has the same pulley number but it doesn't show a set screw. :eusa-think:
was it also a difference between a 8 speed vs hydro thing?
squonk
I have a 520 and a C145 1100 pulley here and no set screw in either.
can whlvr
no set screws,so what holds them from migrating?
buckrancher
the cooling fan
varosd
seems strange that some of the pulleys have a set screw and some don't.
not sure if they were added on later models as a improvement, like the addition of the 2nd set screw for the hubs.
buckrancher
you are better off with a set screw in the pulley I have seen the non set screw pulleys center bore and pump shaft become worn and allow the pulley to shake a slight amount
this causes a vibration in the drive belt which you hear as a metallic ring in the belt guard
be sure to use anti-seze on the pulley and set screw
Brian
