HorseFixer 2,012 #26 Posted April 1, 2014 (edited) Stevebo, I wouldn't sell yourself short by no means. That JB weld is some pretty good stuff na I have used it many times. This afternoon I will start layin some reinforcement beads down on the backside of that rim and see how that Lab Metal stuff works as I picked up a couple cans of that stuff today. ~Duke Edited April 1, 2014 by HorseFixer Share this post Link to post Share on other sites
shorts 182 #27 Posted April 1, 2014 Bob, Have you contacted Coker tire in Tn. they are real popular with the vintage car guys for tire and wheel related stuff. 1 Share this post Link to post Share on other sites
HorseFixer 2,012 #28 Posted April 1, 2014 Shorts. Yeah I remember you telling me about them. Thanks for the Reminder and Well yes I just called them told them what I need and they Reffered me to ME MILLER TIRE. I cant find a Major American Tire Company that Makes a 4X12 Tri Rib Front and a 8X16 Ag Tire Rear! and I dont want to put Shing Lee Flooey or Shlimp Flied LICE on my ride! ~Duke 1 Share this post Link to post Share on other sites
stevebo-(Moderator) 8,363 #29 Posted April 1, 2014 Original front tires for that tractor are 3.5 wide but are now easy to come by. If anyone has a source please let us all know. 1 Share this post Link to post Share on other sites
C-101plowerpower 1,606 #30 Posted April 1, 2014 Original front tires for that tractor are 3.5 wide but are now easy to come by. If anyone has a source please let us all know. these? http://www.bandenservicezuidwest.nl/webshop/artikel_detail.php?i_art_id=8496 and for the rears http://www.bandenservicezuidwest.nl/webshop/artikel_detail.php?i_art_id=8986 both are bkt brand tires, don't know where they come from but they are pretty good for their price Koen 1 Share this post Link to post Share on other sites
stevebo-(Moderator) 8,363 #31 Posted April 1, 2014 Those are 4.0 not 3.5 wide unless I missed something.. 1 Share this post Link to post Share on other sites
C-101plowerpower 1,606 #32 Posted April 1, 2014 Those are 4.0 not 3.5 wide unless I missed something.. those are 4.0, but does the .5 really matter? Koen 1 Share this post Link to post Share on other sites
HorseFixer 2,012 #33 Posted April 2, 2014 Well actually my front tires are 3.0 X 12 and I surely cant find any of those but all I have found is 4.0 X 12 All I think I can find is the 4.0 has anyone seen any less wide? ~Duke Share this post Link to post Share on other sites
HorseFixer 2,012 #34 Posted April 3, 2014 Started in welding on the worse rim so I fired up MR.TIG and first started with the holes that were seen in the rims. Next were the large craters caused by the chloride (that's stuff should be outlawed) after that I went after all the small craters. Before I finished I used 5 sticks of filler rod. I ran the tig torch slowly over all the bad areas and a couple burn through's occurred so I filled them. I feel confident that I have enough material and have brought the rim thickness back up where it should be. I then spread in some Lab Metal time will tell how this product performs so far I like what I see. Here are some pics. ~Duke 5 Share this post Link to post Share on other sites
Ken B 3,164 #35 Posted April 3, 2014 Thats the ticket Duke, lookin good! 1 Share this post Link to post Share on other sites
stevebo-(Moderator) 8,363 #36 Posted April 3, 2014 Yes the extra 1/2 inch on the fronts do matter. If you look at the front end of many of these seniors they have been "knotched" so the inside of the wider tires do not rub. @Duke there are different true widths of the 4 inch wide tires so I would search for the the narrowest set you can find.... 1 Share this post Link to post Share on other sites
neil 2,410 #37 Posted April 3, 2014 looks great Bob, as long as the rim is structurally sound the rest is just cosmetic ,I know not ideal but even if it last for 5 years of more gives time to aquire a replacement rimor find an alternative . although not as bad, mine are in a similar state of moon like surface , besides i think its sometime nice to see a few battle scars.. 1 Share this post Link to post Share on other sites
ol550 830 #38 Posted April 3, 2014 Duke, any chance you can move the spokes on the front hub to allow for a wider tire? 1 Share this post Link to post Share on other sites
HorseFixer 2,012 #39 Posted April 4, 2014 Yes the extra 1/2 inch on the fronts do matter. If you look at the front end of many of these seniors they have been "knotched" so the inside of the wider tires do not rub. @Duke there are different true widths of the 4 inch wide tires so I would search for the the narrowest set you can find.... Stevebo, Guess I have never paid attention to any seniors being Notched What do they notch and could you measure your tires and lemme know what they are at the thickest part So's I can have a refrence to go by? Thanks ~Duke Duke, any chance you can move the spokes on the front hub to allow for a wider tire? Mike Good question, I hope I wont have to do that. ~Duke Share this post Link to post Share on other sites
HorseFixer 2,012 #40 Posted April 17, 2014 I was out working on the Senior yesterday evening and tried to Start the Wisconsin engine & discovered I had a very weak Spark I could read some spark through a Neon Spark Plug Tester but it would only light up one side which indicates a weak spark. I could get no spark across the plug. So this morning I dove into the Wico Mag. The first thing I ran into was a suspect Condenser kinda looks like sumptin may have got a lil warm? I then looked at the points and they looked like sandpaper. Then I took off the plug wire and Introduced it to MR. Ohm Meter and all I can say is 28.12 Ohms on the old wire compared to 0 zero Ohms on a fresh New Belden is no doubt a little difference in those resistance readings. I cleaned and re gapped the points, put an oddball new condenser in and replaced the Plug Wire still not much fire in the hole. I did some research and talked to a guy on the Net who rebuilds and sells these Wico Parts and he says 9 times out of 10 when he rebuilds one it has bad points, condenser or Coil. Well I have those parts coming hopefully by the weekend. Well this answers a few questions as a little more of the Mystery or History of this Senior is coming to light . My WH Dealer friend who I got the Tractor from told me how he came about it. He said a guy brought it to him because it quit running and wanted to trade it in on something. So there it is Mystery Solved and I am soooo glad to know that was the reason.... Or at least I hope so. I will just have to keep my fingers and hope that I can get it running decent. I have it up on jacks with the wheels off so I may be able to get an indication of the drive train condition. Here are some pics. ~Duke Share this post Link to post Share on other sites
Martin 2,133 #41 Posted April 17, 2014 enjoying the updates on this one, Duke. heres for the ignition being the main reason for the engine not running. 1 Share this post Link to post Share on other sites
fireman 1,022 #42 Posted April 17, 2014 Hey Duke, If your going to the show I can have one of the CT guys bring that Wisconsin down! 1 Share this post Link to post Share on other sites
HorseFixer 2,012 #43 Posted April 19, 2014 enjoying the updates on this one, Duke. heres for the ignition being the main reason for the engine not running. Thanks Martin, Parts didn't come today so I am still crossing my fingers. ~Duke Hey Duke, If your going to the show I can have one of the CT guys bring that Wisconsin down! Thanks Jeff, I am going to try and get this one running first cause I would like to keep what's on the Tractor, I think you can appreciate that. As for the Show don't think I can make it. ~Duke Share this post Link to post Share on other sites
fireman 1,022 #44 Posted April 20, 2014 I hear ya. Same goes for me as far as the show. Got a lot going on all around the same time. 1 Share this post Link to post Share on other sites
rwilson 128 #45 Posted April 21, 2014 I like seeing guys bringing these old Wico's back to life! Nice job on the rim too. 1 Share this post Link to post Share on other sites
ol550 830 #46 Posted April 21, 2014 Worked with an old timer many years ago that worked on all the mags that came into the shop. First thing he would do is clamp them in a vise. Never turned one until securely fastened. Kept him from throwing it when it lit up. 1 Share this post Link to post Share on other sites
SousaKerry 502 #47 Posted April 21, 2014 Watch out when you get that old Wico sparkin when they are good and hot they will knock you on your A$$ real fast. Played with a few and found out the hard way more then once. 1 Share this post Link to post Share on other sites
shorts 182 #48 Posted April 21, 2014 I used to work in a marina, we had a spinner box built into an angle iron bench with a wood top, standard procedure was to remove the mag and put it on the spinner box to set the spring tension on the points and then spin the mag to set the dwell instead of just using feeler gauges, Rule 1, ground the coil output before turning on the spinner box/motor, did I mention make sure to ground the coil output before turning on the spinner box, Rule 2, don't touch the angle iron frame of the bench while you're holding the body of the mag and spinning it to set the points, final test was to disconnect the coil output ground and check for spark while spinning the mag. anything less than a spark that would jump a 1'' air gap was considered unacceptable. If you don't think that that much spark will light your fire try becoming the coil out ground or get close to the bench frame and be the air gap to test the coil for spark, you won't do it a second time. 2 Share this post Link to post Share on other sites
HorseFixer 2,012 #49 Posted April 27, 2014 (edited) Well I got the Wisconsin engine going. I rebuilt the mag and then the carburetor. I am pretty happy that the ole girl doesn't smoke so that is good news. Here is a video of the engine running. I had a Couple Pal's stop by today all the way from New York so They helped me run it through the motions and take this Video. Not seen Is Buckranchers better half Jo on the Camera. Really enjoyed the visit! Edited April 27, 2014 by HorseFixer Share this post Link to post Share on other sites
stevasaurus 22,909 #50 Posted April 27, 2014 (edited) :)Excellent video Bob...always nice to have good help. Edited April 28, 2014 by stevasaurus 1 Share this post Link to post Share on other sites
