fishingstararlake 1 #1 Posted March 17, 2014 I have a 520 h and need to replace the idler pulley transaxles drive. All the parts diagrams are not showing it. It started to make noise last fall and checked it out then and got some chain lube in it. Now I would like to replace it and can't find it. Can anybody help me out? Dan Share this post Link to post Share on other sites
BOWTIE 226 #2 Posted March 17, 2014 YOU SHOULD BE ABLE TO BUY IT AT NAPA or SOMEBODY THAT SELLS SMALL ENGINE PARTS KNOWN AS PRIMELINE. WHAT YEAR IS TRACTOR? BOWTIE Share this post Link to post Share on other sites
fishingstararlake 1 #3 Posted March 17, 2014 It is a 91 the m/ 4120oe02 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,171 #4 Posted March 17, 2014 Download part 1 and the 112791 idler pulley is on page 10. Stens 280-586 may be the same. Garry Share this post Link to post Share on other sites
BOWTIE 226 #5 Posted March 17, 2014 TORO/ WHEEL HORSE NUMBER 112791. EXPENSIVE THROUGH THEM ,I SHOULD BE ABLE TO COME UP WITH A AFTERMARKET PART NUMBER. BOWTIE Share this post Link to post Share on other sites
illinilefttackle 399 #6 Posted March 17, 2014 Does it look like this?-if it is made up of two sides, riveted together, capturing a bearing in the middle, you are better off replacing the bearing-the new stens pulley, pictured also, has a much smaller bearing-just drill out the rivets-and replace the bearing-then rivet it back- much stronger-Thanks-Al Share this post Link to post Share on other sites
