Electro12WH 50 #1 Posted September 13, 2008 Which brand of spark plug do you think works best in a Kohler K series engine? Share this post Link to post Share on other sites
TT-(Moderator) 1,131 #2 Posted September 13, 2008 I use only Autolite or NGK brand spark plugs in mine. Share this post Link to post Share on other sites
Kelly 1,029 #3 Posted September 13, 2008 I also have had good luck with the NGK's Share this post Link to post Share on other sites
WheelHorse_of_course 99 #4 Posted September 14, 2008 It would be if you guys could post the numbers you are using in these non-champion brands, :banghead: Share this post Link to post Share on other sites
64s 83 #5 Posted September 14, 2008 I've always used Champion but recently have been thinking about the E3's. Has anyone used them? If so, would you recommend them??? :banghead: Share this post Link to post Share on other sites
linen beige 14 #6 Posted September 15, 2008 It would be if you guys could post the numbers you are using in these non-champion brands, I try to use Champions too, mostly because the numbers are easily found, and they are stocked almost everywhere. A cross reference would be very handy! Share this post Link to post Share on other sites
Buzz 502 #7 Posted September 15, 2008 Here's a site I found that cross references most brands. A little tricky to use though: http://www.clubplug.net/cross.html I had a better one bookmarked but lost it :banghead: Share this post Link to post Share on other sites
kpinnc 12,175 #8 Posted September 15, 2008 I seem to recall one that said "GATOR" on it, and though I don't have one, it is my favorite... :banana: :banana: :banana: Kevin Share this post Link to post Share on other sites
TT-(Moderator) 1,131 #9 Posted September 16, 2008 :thumbs: Share this post Link to post Share on other sites
Duff 206 #10 Posted September 16, 2008 TT, where DO you come up with all this stuff????? Duff :USA: Share this post Link to post Share on other sites
TT-(Moderator) 1,131 #11 Posted September 16, 2008 That was in a small block Kohler parts engine I bought at the local small engine shop. I need to find it again and get it sent to Kevin. :banghead: Share this post Link to post Share on other sites
