grinchsr 634 #1 Posted March 12, 2014 (edited) I AM CONSIDERING THE PURCHASE OF THIS REAL NICE B60 WITH A CART - SICKLE BAR - BLOWER AND A DECK. THE CART IS STANDING UP ON THE SIDE OF THE TRACTOR PIC AND THE SICKLE BAR IS HANGING ON THE WALL. I HAVE NOT SEEN IT YET. JUST HAVE PICS. I DO KNOW THE MOTOR WAS UPGRADED TO AN 8 HORSE. THE OWNER WANTS $2000.00 https://lh4.googleusercontent.com/-7LUKa2t_Jhk/UyBtvmrOgPI/AAAAAAAAAgI/SWKqNDk5VcE/w1297-h973-no/DSC00555.JPG https://lh4.googleusercontent.com/-qoP7QuwaFLg/UyBtvjAUG9I/AAAAAAAAAgI/eT__ZDRVpp8/w1297-h973-no/DSC00556.JPG https://lh4.googleusercontent.com/-M-KNoV8P0uE/UyBtvt0lwMI/AAAAAAAAAgI/6sHMdposDKA/w730-h973-no/DSC00558.JPG https://lh6.googleusercontent.com/-OZ7a3nTcmJQ/UyBtvn_Mq2I/AAAAAAAAAgI/-0FDr6K8Qsk/w1297-h973-no/DSC00557.JPG Edited March 12, 2014 by grinchsr Share this post Link to post Share on other sites
slammer302 2,155 #2 Posted March 12, 2014 If everything is in working order I would be all over it I not going to price someone else's stuff but I know sickle bars are sought after and can be worth more than a person would think Share this post Link to post Share on other sites
stevasaurus 22,813 #3 Posted March 12, 2014 Everything looks to be in great shape...do not see the cart in the pictures. I would think top end is about $1500. Blower $200 to $300, Sickle Bar $300, mower deck $150, Tiller $350, Cart $100 to $200, Horse looks great, tires, weights, seat all looks good. $400 to $500. My 2 cents 1 Share this post Link to post Share on other sites
bmsgaffer 2,045 #4 Posted March 12, 2014 I think that the tractor is underpowered for all those attachments, but in the condition it is in with all those attachments it probably is close. Maybe start at $1500? To be clear, you are mostly paying for the attachments, the tractor is in good shape but not worth much of that total. Share this post Link to post Share on other sites
Lane Ranger 10,977 #5 Posted March 12, 2014 I would day that you need to know that the 8 HP motor is not as big as you may need to efficiently operate the tiller and sickle bar mower. The mower deck will be ok with the *HP. If you think about it you are buying a tractor and four implements , a cart, a Tiller (I do not see a snowblower in the pics), a mower deck -side discharge, and a sickle bar mower (42 0r 50 inch not sure from photo). You can get good 8 HP Wheel Horse tractors with mower decks and a Kohler engine for under $700. They pretty regularly listed on Ebay or Craigslist. So you are buying four implements for about $1300 (unless you are getting a snowblower also) . Share this post Link to post Share on other sites
bmsgaffer 2,045 #6 Posted March 12, 2014 I would day that you need to know that the 8 HP motor is not as big as you may need to efficiently operate the tiller and sickle bar mower. The mower deck will be ok with the *HP. If you think about it you are buying a tractor and four implements , a cart, a Tiller (I do not see a snowblower in the pics), a mower deck -side discharge, and a sickle bar mower (42 0r 50 inch not sure from photo). You can get good 8 HP Wheel Horse tractors with mower decks and a Kohler engine for under $700. They pretty regularly listed on Ebay or Craigslist. So you are buying four implements for about $1300 (unless you are getting a snowblower also) . Snow blower is attached to the tractor... Share this post Link to post Share on other sites
Hodge71 664 #7 Posted March 12, 2014 I think that the tractor is underpowered for all those attachments, but in the condition it is in with all those attachments it probably is close. Maybe start at $1500? To be clear, you are mostly paying for the attachments, the tractor is in good shape but not worth much of that total. I agree with everything BMS is saying but I would start at $1250 and see if you can end up at $1500. As nice as that tractor is, its only an 8 HP. I would put its value at $150 without a deck and $300 with the 36" deck. If it was a 10 or even a 12 horse I would give 4 to 500 for it without anything in its present condition... I would give you 400 for the sickle bar as it sits without even seeing it in person. Share this post Link to post Share on other sites
rmaynard 15,576 #8 Posted March 12, 2014 About three years ago, I saw a C-120 with tiller, 42" SD deck, bathtub cart, snow plow, snow blower, and a cab advertised for $1500.00. The condition was every bit as nice as this one. It sold quickly. My biggest problem with the set-up you have presented is that even with an 8 hp engine upgrade, you are still way under powered for the accessories. My neighbor had a C-81 (8 hp) with a snow blower, and the slightest grade would render it useless. He re-powered with a 14 hp. Share this post Link to post Share on other sites
pfrederi 17,800 #9 Posted March 12, 2014 I have to disagree with some of underpowered comments. I believe B60s were all 8 speeds, gearing is what you need. Sickles do not require much power. Slow speed yes. My 753 has no problem with its sickle bar ...since I made it an 8 speed. You have to go slowly with sickles. I have a 7ft sickle bar I use with my Case DC3 Tractor (she is about 40hp) but with the sickle you are in first gear with the engine loafing. Tiller looks to be in great shape, hardly any wear on the tines, again 8hp is more than enough since you till in 1st or 2nd low range. Snowblower will work but more HP would be better. 1 Share this post Link to post Share on other sites
grinchsr 634 #10 Posted March 12, 2014 GREAT INFO AND I THANK YOU ALL. I KNOW THE PRICE WAS HIGH BUT I DID NOT KNOW HOW HIGH. I NEED TO GO AND CHECK ALL THE PIECES AND MAYBE MAKE AN OFFER Share this post Link to post Share on other sites
rustyoldjunk 127 #11 Posted March 12, 2014 IIRC The B60 is a rare tractor too and kind of unique in the fact that it is a B with the smallest engine yet it came with the big 8 speed with 1 1/8th axles and 8 pinion differential. Share this post Link to post Share on other sites
grinchsr 634 #12 Posted March 12, 2014 I DID NOT KNOW THEY PUT THE BETTER REAR IN THOSE. I NEVER OWNED A 70'S HORSE. I HAVE AN 88 AND A 92 Share this post Link to post Share on other sites
rmaynard 15,576 #13 Posted March 12, 2014 I have been trying to get my hands on a rust-bucket B-60 near me, but the owner won't sell. I think he knows what he has. Share this post Link to post Share on other sites
grinchsr 634 #14 Posted March 12, 2014 So does mine Share this post Link to post Share on other sites
grinchsr 634 #15 Posted March 12, 2014 CAN ANY ONE TELL ME IF THIS TILLER WILL FIT ON MY 312-8? Share this post Link to post Share on other sites
Hodge71 664 #16 Posted March 12, 2014 Absolutely . You just need the over axle lift tube and cable along with the rear axle bracket for the plow/tiller to make it work Share this post Link to post Share on other sites
Desko 609 #17 Posted March 12, 2014 I have to disagree with some of underpowered comments. I believe B60s were all 8 speeds, gearing is what you need. Sickles do not require much power. Slow speed yes. My 753 has no problem with its sickle bar ...since I made it an 8 speed. You have to go slowly with sickles. I have a 7ft sickle bar I use with my Case DC3 Tractor (she is about 40hp) but with the sickle you are in first gear with the engine loafing. Tiller looks to be in great shape, hardly any wear on the tines, again 8hp is more than enough since you till in 1st or 2nd low range. Snowblower will work but more HP would be better. the part about your sickle bar on you case. We have a ford 3000 same hp as the case I can run our 7ft sickle mower in high 5 no problem why do you run such a low gear? Share this post Link to post Share on other sites
can whlvr 993 #18 Posted March 13, 2014 I guess it depends on conditions of soil or snow,i run a tiller on one of my 414,sthe motor is in very good shape and at times she can be bogging down,even in low 1st,i have a 308 that the 8 horse blew apart years ago,if you want a worker I would not go lower than 12hp,i know lots of guys say that tha small blocks are plenty powerful,but it takes its toll on the small motors when working them all the time,i have had an 8hp,and still have a 10,12 13,14,16hp tractor,it is in nice shape though Share this post Link to post Share on other sites
Racinbob 11,136 #19 Posted March 13, 2014 I have to agree with pfrederi on the horsepower. I bought a new 76 B80 and had no problem running the same attachments. More would have been better with the snow blower. I did end up putting a 16hp on it but that 8 went on an 854 and was still running strong 20 years later. Share this post Link to post Share on other sites
grinchsr 634 #20 Posted March 14, 2014 THANKS FOR ALL THE FEEDBACK. I BOUGHT ALL FOR $1150.00 Share this post Link to post Share on other sites
Ed Kennell 38,504 #21 Posted March 14, 2014 Guess you're now the Grinch that stole WH. Share this post Link to post Share on other sites
Racinbob 11,136 #22 Posted March 14, 2014 In my opinion, you did great. Actually, outstanding. Just price out buying the tiller, blower and sickle bar and you'll find that you have very little in the tractor and mower deck. Plus, you got a set of wheel weights.You've got a great tractor and if you decide, like I did with my B80, to boost the HP it's a simple swap. Share this post Link to post Share on other sites
pfrederi 17,800 #23 Posted March 14, 2014 You got a great deal.... Share this post Link to post Share on other sites
KC9KAS 4,741 #24 Posted March 14, 2014 THANKS FOR ALL THE FEEDBACK. I BOUGHT ALL FOR $1150.00 You really got the PO down from $2000! Good dealing! Share this post Link to post Share on other sites
AMC RULES 37,134 #25 Posted March 14, 2014 Sounds like you did some good trading there. Share this post Link to post Share on other sites
