WHEEL HORSE BILL
It runs only with starter engaged
WHEEL HORSE BILL
Those wires have been bypassed by the original owner.
rmaynard
  On 3/3/2014 at 9:58 PM, WHEEL HORSE BILL said:
...if I turn the key and hold it with my fingers pegged all the way it stays running...
Correct me if I'm wrong, but is this not the original problem?
WHEEL HORSE BILL
Bob can I send you a video by cell phone
Hodge71
Im totally and completely lost here Bill. You say it starts and runs for an few seconds and shuts off. Then you say it keeps running if you hold the key on. You shouldn't be holding the key for a few seconds after its running. So is the starter engaged while its running? Then you leave the key go and the starter it disengages and it shuts off? Or does the starter engage and the tractor starts and runs and then shuts off after a few seconds but if you hold the key on the starter is disengaged but the engine remains running? Are you 100% positive you wired it correctly?  Depending on your answers the the previous questions it sounds like it wired wrong. I may be wrong but you have a 20 year journeyman electrician lost …..Feel like I'm  :deadhorse: here but what you're saying makes no sense. It works, it doesn't work, it runs…no wait now it shuts off….. Please help us, so we can help you. These tractors are not rocket science…. There's  basically 4 wires that do everything including lights….Step back regain your composure and look at things again with a fresh head. You sound very frustrated and you can't do anything correctly like that
Edited by hodge71
WHEEL HORSE BILL
wiring I want to give up.
Edited by WHEEL HORSE BILL
Hodge71
Okay…If thats how you feel…. its not the tractors fault you're having these issues…good luck
WHEEL HORSE BILL
OK, I turn the key and the engine starts but as soon as I let go of the key the tractor shuts off.  The starter engaged makes the motor run if I let go of the key the starter will disengage and shut off the engine.  I know it sounds confusing but I have tried everything!
rmaynard
I'm going to ask you one more time, do you have a multimeter?
Hodge71
Exactly what he just asked… If you don't…you need one and a knowledge of how to use one. Its the only thing that will help you fix this issue
WHEEL HORSE BILL
I don't have one all I have is a test light. I guess I should invest in one.
rmaynard
How have you been checking the wiring without a meter? Are you using a test light?
A visual check of a wire will only reveal if it is physically there. It will not check to be sure that it is good.
chazm
Well ...I'll throw in my  :twocents-02cents: ...  naw... it won't help the cause :dunno:
WHEEL HORSE BILL
I just retraced every wire visually no test
gwest_ca
Double check the seat switch bypass and make sure that connection is good and not just looks good. That connection should power the ignition coil in the run key position. Now turn the key switch to the run position. If the starter engages in the run position the wiring is reversed at the pto switch or is that bypassed also?
If the pto switch is still in the circuit apply the pto switch and try again.
Let us know what happens and when.
Garry
rmaynard
Unless you get an inexpensive meter or a 12 volt test light, it is next to impossible to help you.
The wire that connects to the "I" terminal on the ignition switch, should go directly to the (+) terminal of the ignition coil. If you say that you have physically checked to be sure that it does, then you have a bad wire or a bad splice in that wire, bad connector on the end of the wire, or a bad ignition switch.
A meter or a test light would be able to prove that.
rmaynard
Go to Walmart or some other store and pick up either a cheap meter  post-2221-0-52856300-1393892806.jpg or a test light post-2221-0-95823200-1393892851.jpg
You should be able to spend about $10.00 on a meter or $5.00 on a light. Once you have one of them in hand, it will be a lot easier for us to help you trace the circuits to see where your problem is.
WH nut
Ok lets short cut this whole issue. Try this. Run a jumper wire from battery plus to the + side of ignition coil and crank the motor. Does it Crank  Yes or No, Does it Crank but no start and run Yes or No. Does it Crank and run yes or no
When you have the answers to these question we can proceed. .
Edited by WH nut
WHEEL HORSE BILL
Rmaynard i do have a test light if that helps us.I just came inside but the black wire does go from I on the switch to the + on the coil.
WH nut
With the switch in the run position is there power to the + side of the coil?
WHEEL HORSE BILL
Where do I attach the clip from the test light thing.positive side of the battery right.
WH nut
To any good ground, Battery - works real good
WHEEL HORSE BILL
okay I put the clip on the negative post to the battery. Then I turn the key to the starting point and yes I do have power to the positive on the coil
WH nut
NO, to the run position!
WHEEL HORSE BILL
Ok the light is not lit.
WH nut
Ok, no go back a page and follow the wire diagram backwards to find the break.  Or you can short cut again and probe the back of the ignition switch and see it the I terminal has power when in the run position
But you say you have changed the switch. You need to make sure you have the right one, or use the original switch.
  • Similar Content
    • t_furl43
      By t_furl43
      1979 c-101 nice project tractor just needs a few odds and ends, steering wheel, coil, carburetor bowl, the wiring was redone by previous owner....all 4 tires are good and hold air it goes into all gears no problem, transmission fluid has been changed, 10hp Kohler, message me or call or txt with any questions, it does run and runs well,  it’s been kept inside since I’ve had it, I would also trade for a mid mount grader blade thanks
      92DB561C-FF95-4868-A52B-5725D4D3B9DE.mp4
    • Wayne Clark
      By Wayne Clark
      I have restored a C-101. 10 HP Kohler - 8 speed - cast iron transmission with 36" deck.
      Any ideas what I could sell it for.  Thanks.  Located in  Imperial, MO.
    • jellyghost
      By jellyghost
      I am the proud new owner of a 1978 C-101.  I bought it yesterday, and it is in amazing condition.  Everything worked except the brake peddle and under chair safety cutoff.
      I started mowing today, and everything was going great.  As it got late, I started using the lights.
      Suddenly, the mower stopped in the middle of a mow.
      Here are the facts that seemed relevant to me:
      The motor won't try to turn on when I turn the key.
      The lights and the electrical won't turn on with the key and switch.
      It has a new tank of gas and fresh oil.
      I inspected the wires, and they look ok at first glance.
      The WH has a car battery dated from April 2011.
      I do not have a black thumb.  I am basically ignorant, but it seems like an electrical issue to me.  Could the battery have completely died even while running?  What do you guys think?  I was hoping to do a post showing this awesome mower, but this happened before I could!
    • Pullstart
      By Pullstart
      Jada decided she wants do drive the wheelhorses because her battery on the simplicity was dead.  She can just reach the clutch pedals and I kept both the 502 and C-101 in low range so no matter what gear she selected it was still slow enough.  I've created another monster!
      click for short videos...
    • Pullstart
      By Pullstart
      So my mom gave us kids cash for Christmas and told us to go find something for ourselves, I took a little 50 some mile road trip this morning and picked up a steel fender C-101.  Overall, it seems to be well taken care of and in great shape!  Except for the connecting rod issue that I knew about before heading to get it.  I have a spare 10 horse that had the carb and starter bits robbed from it before I picked up my 8 speed donor for the 502 so I should be able to use the left overs to get this back running.  Came with a RD deck and a big folder full of service records and receipts.  All in all, this will be a worker and should give me the ability to refresh my 502 without the worry of  downtime!
