speedyleedy 205 #1 Posted February 18, 2014 I just replace the drive belt on my 857 with a 1/2 by 70 " belt from tsc but it will work with out the belt guard off but everytime i put the belt guard on it & will not work it's like the belt loosen up & won't take hold is there anybody out there that can help out with what i am doing wrong.Thanks Share this post Link to post Share on other sites
TT-(Moderator) 1,145 #2 Posted February 18, 2014 Is the tensioner pulley assembly hitting the inside of the guard before the belt tightens? Share this post Link to post Share on other sites
daveoman1966 3,762 #3 Posted February 18, 2014 Not sure about the 857, but on MANY other Wheelhorse tractors, there is a belt guide welded to the back-side of the belt cover. The flat side of the belt has to ride atop this guide or it will not work correctly. The other consideration is that after-market belts are ill-fitting for Wheelhorse applications. Generally, the geometry of the after-market belts do not PRECISELY match the V pulleys and will ride higher or lower than designed. Whats more, the sides of the belt won't make FULL contact with the pulleys, giving rise to belt slip and premature failure. Share this post Link to post Share on other sites
speedyleedy 205 #4 Posted February 18, 2014 I think the tensioner is hitting guard & maybe the belt is also riding to high in the pulley too ? Share this post Link to post Share on other sites
Hodge71 664 #5 Posted February 18, 2014 Wheel Horse belts are between an A and B in profile. Buying aftermarket belts will never work as well as an OEM belt. It will ride either higher or lower depending on what you buy. Either way you are not getting proper power transfer to you pulleys and often they will slip or not work at all. Another thing Wheel Horse did was to make their belts an odd length so that you can get close but it will be either too long or too short. Speaking from experience, I have taken the cheap route and tried to buy other non OEM brands…its not worth the hassle and I will never waste my time or money to buy junk again 1 Share this post Link to post Share on other sites
speedyleedy 205 #6 Posted February 18, 2014 Thank you so much for you help hodge Share this post Link to post Share on other sites
bubbacola 8 #7 Posted February 20, 2014 Go to Toro and get the right belt.. after market match ups don't work. Been there done that Share this post Link to post Share on other sites
