Hodge71
Bearing number from a c series wheel
Hodge71
Can anyone help me out with a bearing number from a C series wheel or a wheel from an 18 Automatic  with a 3/4" shaft. Not the Wheel Horse part number, a Timken number or SKF number that I can cross over if need be. Any help is greatly appreciated.
gwest_ca
Does this bearing need to have a 1-3/8" OD?
Garry
gwest_ca
One seal on the outside
https://www.bantasaw.com/catalog/viewproduct.asp?i=&p=380
Two seals
https://www.bantasaw.com/catalog/viewproduct.asp?i=&p=391
These are Stens parts. One seal allows you to grease with a gun because grease can escape past the outer seal.
With 2 seals you can not grease it so the grease fitting should be replaced with a set screw. The grease can't get past the inside seal so the pressure tries to push the bearing out of the hub.
Napa carries both styles also but our dealer does not recognize the differences and consequences.
Garry
Hodge71
Thanks Garry. I appreciate it. With this info I can figure out possible fixes for my trashed 18 auto front wheel...
56flatbed
Hey Garry, tell your NAPA dealer to get in his books and learn something!   SKF bearings (Napa branded) uses a suffix to determine whether the bearing has 1 seal, 2 seals or none.  Example   6205, 6205J, 6205SJ, 6205RSJ.  These would all be the same bearing with a variation on the seals.
I take the parts business seriously, I retired from NAPA in 2012 after 23 years.  Hope this helps.
gwest_ca
I believe Napa gets their Outdoor Equipment parts from Prime-Line which is a company like Stens. These flanged bearings are in a different league than industrial bearings so numbers are also different.
Garry
56flatbed
Garry you are right, still got my head in the automotive world.
  • Similar Content
    • Rentalman
      By Rentalman
      I've been a Wheel Horse Dealer since 1979. I still have (12) 48"Snow/Dozer Blades still available Model # 79364. I am selling these for $250 ea. Well under dealer cost and a steal from the MSRP of $699, I got stuck with a shipment of 26 8 years ago.They fit all CSeries-300Series-400Series and some 500Series but adaptor kit needed
      You can reach me at Gaithersburg Rental
                                        219 E Diamond Ave
                                        Gaithersburg, Md 20877
                                        301-926-0044
                                       mon-sat 730-530
