PMaine
516H Eaton 700 failure
boovuc
Give me a PM. I have one in my shed. (I think). Please call me before you spend some bucks. I can send this one up to you. I don't need it!
PMaine
Darn, already paid for the one on ebay! Thank you though!
PMaine
Here's a picture of the JB weld job. Obviously someone who didn't know what they were doing dug into this eaton for a reason, I will put the reservior in but I still have my doubts that this is a good unit.
On my 252-H this JB welded area is where the reservior screws into, on this tractor there isn't clearance for it here, and I assume there should have just been a plug in this threaded area.
While I wait for the reservoir I figured I would start cleaning things up. I used POR15 as a primer. I will do the seat pan next.
I got the snowblower at a hardware store on the way home, had to drag it by myself through a field but it was worth it. $200. Total investment thus far is $650.
Edited by PMaine
PMaine
Okay guys I took a trip to see Dennis yesterday for a rolling chassis. The new eaton 1100 is night and day, but I have a few questions.
The power lift will not work when first started. It takes about a minute to get a response from the lift cylinder.
My other problem is the reverse is very slow but I think I just need to adjust the linkage!
It was a fair amount of work to do the swap and add the hydraulic lift system but it really makes the tractor!
Thank you again Dennis!
smoreau
It is normal for them to not work right away when its cold out. I have to let mine run for a few min. before I use mine.
PMaine
Interesting thanks! I adjusted the shift lever and all is well, looks like now I can start enjoying the tractor!
dennist
Glad your up and running.
dbartlett1958
I use full synthetic in my Hydro. Makes the lift start working quite a bit sooner.
Now get yourself one of Matt's foot pedals once you get the bugs sorted out.
Edited by dbartlett1958
Kelly
I run Mobil 1 in my hydros it helps alot on the cold sluggish lift.
